Old 04-17-2015, 03:55 PM   #11
rbq
Use hollow core door anchors. Have been pleased with how well they have worked on projects in our Roo.
2001 Chevy Silverado
2011 Rockwood Roo 233S
rbq is offline   Reply With Quote
Old 04-17-2015, 04:04 PM   #12
Ann
RverAnn45's Avatar
To hang the TP or not
We decided NOT to make unnecessary holes in the walls. I hung a bag holder from the rod over the toilet. Squeeze a TP roll and it slides through the top easily. At least 3-4 rolls hang this way. I try to put rolls in this bag with have a few sheets removed because they are easier to get out through the bottom.
I leave one roll out, on top of a plastic coffee can, which we use as a paper wastebasket (with a liner). This goes into the shower during travels.
Ann
RverAnn45 is offline   Reply With Quote
Old 04-17-2015, 04:32 PM   #13
DaveSchwartz's Avatar
Since the toilet roughly faces the vanity and the wall is curved, so no way to really attach to that, I glued about a 6" piece of 1x4 (3/4 x 3 1/2) pine to the inside of the vanity door panel using Gorilla glue and then screwed the holder to that. Works well and totally hidden out of the way when not needed.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 04-17-2015, 04:47 PM   #14
Our new 2008 Shamrock 183 came with neither toilet roll holder nor towel holder attached. At the time I figured if the factory was afraid to attach them then so was I. Use a free standing holder (its a resin bear so it goes with all the other bear stuff my wife put in the camper). For towels, we bought an over the door holder. Both work well and we just transferred both to our new Shamrock 231KSS.
CNYCamper is offline   Reply With Quote
Old 04-17-2015, 04:52 PM   #15
Originally Posted by suscamper View Post
Our new Forester 2501 came with the toilet paper holder in a box. At walk through the man said that's so you can attach wherever you want. We can't figure out where to put it where it won't rip out if the wall. In a house we'd look for studs or use a molly. The bronze screws wound work with mollys anyhow. Any suggestions?
Do you have a shower enclosure? Mounted ours on the side of the shower.
Name:	Toilet Paper Holder.JPG
Old 04-18-2015, 12:03 PM   #16
Unless you get violent when taking paper off of the roll it shouldn't matter. Ours has been screwed into the wall board for three years and is still solid.
VMI'62
Edmund is offline   Reply With Quote
Old 04-18-2015, 12:07 PM   #17
Good luck with this. Our Salem Ultra-lite came with one on the wall directly in front of the toilet. First time we put a roll on it, everything fell to the floor! The screws weren't fastened to anything behind the paper thin paneling. We put the roll inside the vanity and use that.
gfarmcafe is offline   Reply With Quote
Old 04-18-2015, 02:49 PM   #18
Crusadernoob's Avatar
I used short bolts with fender washers on the inside of the vanity. Has worked very well so far.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 14
Crusadernoob is offline   Reply With Quote
Old 04-18-2015, 03:36 PM   #19
redcloud1's Avatar
Toilet paper holder
I mounted ours to the bathroom door. Working good there.
redcloud1 is offline   Reply With Quote
Old 04-18-2015, 05:44 PM   #20
On our 2501, ours is hanging on a thin rope from the shower enclosure top rail. Swing it out when we are using it, swing it in and close the door for travel. Looks a little redneck, but hey. JH
micpib1 is offline   Reply With Quote
