Old 05-08-2011, 06:00 PM   #11
Oakman's Avatar
I've owned fifth wheels for 7 years and I never drain the water heater until it is time to winterize it. The water won't go bad. There have been times when the trailer wasn't used for six weeks.
After you break camp and disconnect from your water supply or, if boondocking and turned off the water pump, just open a faucet to relieve the pressure and then close the faucet.
Don't make camping a chore.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 05-08-2011, 06:02 PM   #12
Send a message via Skype™ to scubieman
Thank you all. I'm going to relax now.
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 05-09-2011, 02:54 PM   #13
jimh's Avatar
I pulled and drained my water heater for the first time this past fall. Mine sets all winter and usually sets more than a month between trips in the summer. Never an issue with water taste. Anode rod had abt half left.
I wouldn't be concerned. Ur anode rod is going to respond to the conductivity (mineral) content of the water. Our water here isn't as much of a problem as other areas.
I purchaced my trailer new 9 yes ago. Our winters aren't as severe so I can get away with covering the outside of the water heater and drain the rest.
jimh is offline   Reply With Quote
Old 05-09-2011, 04:50 PM   #14
Do u bleach your tank?
Old 05-09-2011, 05:51 PM   #15
backin15's Avatar
Yes, you should bleach the tank. If you drain the water heater you will still have some water left in the lines and in the filter. If you are concerned about water getting nasty you should also be concerned about this water too. I just leave the water in the heater and if it is more than a few weeks between trips fill the fresh water tank and add the bleach. Open the faucets and when you smell the bleach you know the water heater has bleach in it. Let it sit a while and flush and you are good to go!
backin15 is offline   Reply With Quote
Old 05-09-2011, 05:58 PM   #16
sherdep's Avatar
dont forget to either remove or replace the filter after you bleach the water - bleach kills the charcoal - or atleast that was what I was told
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 05-09-2011, 06:30 PM   #17
I do not have a filter. Well I guess I kind of do. It's just a sand filter. Large particle stopper.
I am usually too concerned about this type of stuff so it's nice to have people fill me in.
Old 05-09-2011, 07:05 PM   #18
flyrotor's Avatar
I drain mine all the time, not for any other reason than I can, simple to do, simple to replace, also it flushes any hard water deposits out of the heater.
flyrotor is offline   Reply With Quote
Old 05-09-2011, 07:36 PM   #19
Danimal's Avatar
i think i seen a replacement plug some where that has a Anode and a drain valve on it so you can use the valve to drain ( no tools )
sorry i cant remember where i seen it, i guess you could google it
2005 Dodge Ram
2011 Rockwood 8281SS
Danimal is offline   Reply With Quote
Old 05-09-2011, 07:43 PM   #20
Herk7769's Avatar
Amazon.com: Camco 11533 RV Anode Rod with Drain for Aluminum Water Heater: Automotive
Looks like it is for the Atwood Aluminum Heater only.
HAM CALLSIGN - KC3FFW
