Old 05-08-2011, 04:51 PM   #1
Send a message via Skype™ to scubieman
How to drain Water heater?
I arrived back from my first RV trip which was AWESOME! Now I would like to drain water heater since I wont use it for about another 2-3 weeks. My water heater has a rod at the bottom(Can't think of name). The one that gets eatin at by corriosn before the water heater. Do I take that out? I dont have a big enough wrench and dont want to really buy one. I also have the hot water low points which did not drain the water. Maybe just slow. Or should I just keep the water in there?
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 05-08-2011, 04:53 PM   #2
It would not let me post.
Old 05-08-2011, 04:58 PM   #3
grhodes50's Avatar
I beleive the anode rod is what your seeing. I can't remember the socket size, but you will need to get one to remove the rod and allow the water to drain. Be sure to open a hot water faucet inside the trailer before removing the rod.
Also using teflon tape on the rod's threads before reinstalling will help the next time you need to remove it.
Gary & Trish
2018 Nights Camped - 5
Old 05-08-2011, 05:00 PM   #4
Is this done at each trip?
Old 05-08-2011, 05:02 PM   #5
sherdep's Avatar
Glad to see your trip went well
I do not drain my water heater after each trip (so far has been 2 to 4 weeks apart) but I also do not live in an area where it freezes that often either.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 05-08-2011, 05:03 PM   #6
j2detroit's Avatar
diconnect water, releve the pressure on the system ,open faucet. remove anode rod from warteheater 1 1/16 inch socket let water drain out then you can eather replce or laeve it out should replace though to keep the unwanted critters out
j2detroit is offline   Reply With Quote
Old 05-08-2011, 05:03 PM   #7
grhodes50's Avatar
I usually drain mine if it's going to be a month or more between trips.
Gary & Trish
Old 05-08-2011, 05:04 PM   #8
Thanks. I'm not worried about the cold , just the water going bad.
Old 05-08-2011, 05:41 PM   #9
bikendan's Avatar
in 5 years of owning my trailer, i've never had to drain my WH.
if a long period of time goes by, i just flush the system out.
never have had bad water issues.
our area water is good but i know that other areas of the country, have bad water.
Old 05-08-2011, 05:47 PM   #10
I have good water. I just don't want it full of bacteria or something else next time I use it.
Its more of going bad once in there. Not the water first water placed in there.
