Old 08-14-2016, 08:02 PM   #21
Originally Posted by DavidBo View Post
Because on mine the T&P outlet is pointed directly towards the gas solenoid valve and all it's wires. I'd rather keep that on the dry side if possible!
I'd rather release all that heat and pressure in a nice, safe sink.
OK. There's method to your madness!
2011 Traverse LT, 3.6L, FWD
Old 08-14-2016, 10:23 PM   #22
DavidBo's Avatar
If only I could get the DW to believe that!
DavidBo is offline   Reply With Quote
Old 08-16-2016, 01:03 AM   #23
I relieve pressure by turning off the water and then turn on the hot water at the sink to relieve pressure. My trailer has a drain plug near the water heater so I open that to get most of the water out before removing the anode rod.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is offline   Reply With Quote
heater, water, water heater
