Why not just put the bleach mixture in your water hose, connect it to the inlet. BUT make sure there is a pressure relief from the tank that works! Usually a 1" hose hanging down with the system drains. If you are going to fill the tank, calculate the amount of bleach needed, empty your water hose, connect it to the tap, pour the bleach slowly into the hose, connect the hose to the inlet and turn on the water. This will clean the hose and tank. Do not run bleach through a carbon filter as this will stop the "activated carbon" from working. I do this to my home water system approximately once a year. Works great.
