Old 10-16-2018, 11:54 AM   #1
How to protect tt during winter when being used often?
I have a Wildwood DSX 40' tt that I will be using at my hunting property. Since I will be using it on the weekends during the winter, what do I need to do to protect it from freezing temps? It will be just south of Dallas so temps usually aren't too low for too long. I will have water hookup and sewer drain into septic onsite. Thanks in advance.
Wayne O is offline   Reply With Quote
Old 10-16-2018, 02:40 PM   #2
Head Rambler
I did a little searching and I couldn't find a DSX, but I found some DLX models.
It being a park model RV, I think if you take a few precautions like leaving the heat on low and draining the water lines it'll be fine in that area.
Gotta go campin!
Old 10-16-2018, 03:42 PM   #3
Yes, it is DLX (stupid autocorrect) 2012 40' pull behind. Thanks for the tip on leaving heat on low and draining lines.
winter
