Old 04-01-2011, 08:42 PM   #21
sherdep's Avatar
Originally Posted by Labzy View Post
Matt, I'm assuming that the 2306 doesnt have that black tank flush option???
No it does not - Let me just say it will be a PITA to drop the tanks
I did not drop the tanks when I installed the Tornado and wished I did for a cleaner install because when you hold a hole saw at an angle it makes a larger hole so with that being said - if you can get one of those angle drill heads that attach to the drill it will make the install alot smoother
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 04-01-2011, 08:45 PM   #22
(Kim)
Labzy's Avatar
Omg......please tell me that just putting a hose that has a rotating spray head, down the toilet will do the trick........(fingers are crossed)
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
Labzy is offline   Reply With Quote
Old 04-01-2011, 08:49 PM   #23
sherdep's Avatar
there are many ways of cleaning the tank - most of it is choice - I chose to install the Tornado - others use the wand down the toilet which is effective but I didnt think it was practical for me due to the fact if you are at a dump station you will not want to drag a hose thru your camper to clean it out - or atleast I dont because if it is anything like pulling your boat out of the water at a ramp you will have impatient people waiting for you to hurry up and go - if that makes any sense.
Old 04-01-2011, 08:51 PM   #24
(Kim)
Labzy's Avatar
Well I thought it was considered rude to flush-out your tank when people are behind you in line.....
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
Old 04-01-2011, 09:02 PM   #25
sherdep's Avatar
I wouldnt know - I have only flushed my tanks out once and I did pull behind someone and he took his time - I also told him no rush and watched / talked to him so I had an idea of what others where doing to clean there tanks - he never went inside to clean the toilet with a wand - he had a clear elbow with a hose attachment and ran the hose on the clear elbow when draining out his tanks.
to me didnt seem effective but he had no issues with it.
Old 04-02-2011, 07:02 AM   #26
MtnGuy's Avatar
That does the trick for me. I do that after about every 3 or 4 camping trips at home, so I don't hold up the line at the dump station. The small amount of water added to my tank is the charge for my next trip.
Old 04-02-2011, 04:51 PM   #27
(Kim)
Labzy's Avatar
Question......
I just saw an add for CLR (you know the calcium, lime, rust stuff) and they have a septic mix.
Does anyone use this for their tanks?
Its supposed to help breakdown organic waste.........so I wonder if I could put a little in the black tank to help prevent hard deposits?
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
Old 04-02-2011, 05:29 PM   #28
acadianbob's Avatar
Good idea . . .
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 04-02-2011, 05:38 PM   #29
Send a message via MSN to twalk47
Pinesol with some water works well also.
twalk47 is offline   Reply With Quote
Old 04-02-2011, 05:46 PM   #30
Question......
Hopefully you don't keep the poop long enough for that to work. With two of us, we dump every 3 days, not long enough for a septic treatment to work. We use the geo method?? . Works very well for us.
Kirk, KN1B
2013 Cardinal 3800FL
2009 GMC 3500HD CC LB SRW
kbrown1075 is offline   Reply With Quote
black water, hose
