Old 04-02-2011, 07:44 PM   #31
I was told by our rep to put a bag of ice down the toilet and drive to the next dump station and it will clean out the wAlls of the black tank. The ice will turn to water and then you can dump it.
rickeypaul is offline   Reply With Quote
Old 04-02-2011, 09:06 PM   #32
Infractee
Originally Posted by Labzy View Post
Well I thought it was considered rude to flush-out your tank when people are behind you in line.....
Then consider me rude!
I am not leaving the dump with an iffy-at-best clean out!
I wait in line like everybody else (when there is one) I don't rush anyone and I do not expect to be rushed either.
If the black tank is not full I will fill it up before heading to the dump then dump the black tank, turn on the water to the black flush and let it run. I will close the dump valve and let black tank fill up about half way again (while holding toilet flush valve open so I can see when tank is getting full) then let her rip again to a full drain then rinse hose with gray water tank.
Unhook, stow everything, wash hands and I am done in 15-20 mins.
I am a bit anal about it (no pun intended) but I like things done well.
RhoZeta is offline   Reply With Quote
Old 04-02-2011, 09:15 PM   #33
kalik282's Avatar
I will close the dump valve and let black tank fill up about half way again (while holding toilet flush valve open so as not build pressure in tank) then let her rip again to a full drain then rinse hose with gray water tank.
If you can "build pressure in tank" then you have some serious problems with the venting system for your tanks!!!
John
John & Nicole
2004 Ford Excursion 6.0L 4x4
2011 Flagstaff 831FKBSS
Nights Camped: '06=122 '07=12 '08=18 '09=10 '10=18 '11=28 '12=16
kalik282 is offline   Reply With Quote
Old 04-02-2011, 09:22 PM   #34
Infractee
John
sorry, brain fart.
Fixed!
Old 04-03-2011, 01:57 AM   #35
Herk7769's Avatar
John,
I think Rodger meant "get a good flow" rather than pressure. The more full your tank is when you dump; the more likely everything that needs to come out... will.
HAM CALLSIGN - KC3FFW
Old 06-27-2011, 09:37 AM   #36
Originally Posted by herk7769 View Post
John,
So I have a 831 KRSS with the flush system but was told to never use that with the black water valve shut because it would build up pressure in the tanks. Is that inaccurate? Can I use that to fill the tank to for flushing? Right now I stand in the bathroom of the camper and gently press the foot pedal of the toilet to make the water run to fill the tank. This takes FOREVER. I would much rather just hook a hose of to the flush and let it run. Can I do that?
jim.ptak is offline   Reply With Quote
Old 06-27-2011, 10:13 AM   #37
Herk7769's Avatar
Short answer is no.
The reason is that without a way to monitor the "fullness" of your tank you can quickly overfill your black tank before you know it. Since the toilet valve is closed water will go up the vent stack and overflow onto the roof and the weight of the column of water will allow no place for the water under pressure to go. The pressure in the tank will build until a weak point (seam; pipe connection; probe hole; valve) is found and escape the tank.
You would be better served making an "extension hose" for your shower hose; remove the shower head and attach the extension hose and open the flush valve. Use the extension hose to fill the tank through the toilet. (ONLY USE IT FOR THAT and never put it IN the toilet).
That way you will see and smell when the tank is mostly full.
Old 06-27-2011, 10:51 AM   #38
I dump bottle of cheap dish soap down into tank along with couple of gallons of water before hitting the road and then empty when get set up at site. Cleans tank and seals. A friend of mine dumps a small bag of water softener down their tank along with the water. After tank drains I dump another couple of gallons down to flush and then close black water and open gray water to flush hose. I leave gray open some during stay.
Hope this helps.
real redhead is offline   Reply With Quote
Old 06-27-2011, 07:31 PM   #39
Herk7769's Avatar
Hope this helps.
I use a capful of liquid laundry or dishwash soap and a capful of Calgon Water Softener as well. I still wait till the "full" light comes on before I dump though. If Turboflush water is available I will dump at 2/3 full but never less.
black water, hose
