Old 04-01-2011, 08:42 PM   #21
sherdep's Avatar
Originally Posted by Labzy View Post
Matt, I'm assuming that the 2306 doesnt have that black tank flush option???
No it does not - Let me just say it will be a PITA to drop the tanks
I did not drop the tanks when I installed the Tornado and wished I did for a cleaner install because when you hold a hole saw at an angle it makes a larger hole so with that being said - if you can get one of those angle drill heads that attach to the drill it will make the install alot smoother
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 04-01-2011, 08:45 PM   #22
(Kim)
Labzy's Avatar
Omg......please tell me that just putting a hose that has a rotating spray head, down the toilet will do the trick........(fingers are crossed)
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
Labzy is offline   Reply With Quote
Old 04-01-2011, 08:49 PM   #23
sherdep's Avatar
there are many ways of cleaning the tank - most of it is choice - I chose to install the Tornado - others use the wand down the toilet which is effective but I didnt think it was practical for me due to the fact if you are at a dump station you will not want to drag a hose thru your camper to clean it out - or atleast I dont because if it is anything like pulling your boat out of the water at a ramp you will have impatient people waiting for you to hurry up and go - if that makes any sense.
Old 04-01-2011, 08:51 PM   #24
(Kim)
Labzy's Avatar
Well I thought it was considered rude to flush-out your tank when people are behind you in line.....
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
Old 04-01-2011, 09:02 PM   #25
sherdep's Avatar
I wouldnt know - I have only flushed my tanks out once and I did pull behind someone and he took his time - I also told him no rush and watched / talked to him so I had an idea of what others where doing to clean there tanks - he never went inside to clean the toilet with a wand - he had a clear elbow with a hose attachment and ran the hose on the clear elbow when draining out his tanks.
to me didnt seem effective but he had no issues with it.
Old 04-02-2011, 07:02 AM   #26
MtnGuy's Avatar
That does the trick for me. I do that after about every 3 or 4 camping trips at home, so I don't hold up the line at the dump station. The small amount of water added to my tank is the charge for my next trip.
Old 04-02-2011, 04:51 PM   #27
(Kim)
Labzy's Avatar
Question......
I just saw an add for CLR (you know the calcium, lime, rust stuff) and they have a septic mix.
Does anyone use this for their tanks?
Its supposed to help breakdown organic waste.........so I wonder if I could put a little in the black tank to help prevent hard deposits?
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
Old 04-02-2011, 05:29 PM   #28
acadianbob's Avatar
Good idea . . .
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 04-02-2011, 05:38 PM   #29
Send a message via MSN to twalk47
Pinesol with some water works well also.
twalk47 is offline   Reply With Quote
Old 04-02-2011, 05:46 PM   #30
Question......
Hopefully you don't keep the poop long enough for that to work. With two of us, we dump every 3 days, not long enough for a septic treatment to work. We use the http://www.forestriverforums.com/for...thod-8499.html . Works very well for us.
Kirk, KN1B
2013 Cardinal 3800FL
2009 GMC 3500HD CC LB SRW
kbrown1075 is offline   Reply With Quote
Old 04-02-2011, 07:44 PM   #31
I was told by our rep to put a bag of ice down the toilet and drive to the next dump station and it will clean out the wAlls of the black tank. The ice will turn to water and then you can dump it.
rickeypaul is offline   Reply With Quote
Old 04-02-2011, 09:06 PM   #32
Infractee
Then consider me rude!
I am not leaving the dump with an iffy-at-best clean out!
I wait in line like everybody else (when there is one) I don't rush anyone and I do not expect to be rushed either.
If the black tank is not full I will fill it up before heading to the dump then dump the black tank, turn on the water to the black flush and let it run. I will close the dump valve and let black tank fill up about half way again (while holding toilet flush valve open so I can see when tank is getting full) then let her rip again to a full drain then rinse hose with gray water tank.
Unhook, stow everything, wash hands and I am done in 15-20 mins.
I am a bit anal about it (no pun intended) but I like things done well.
RhoZeta is offline   Reply With Quote
Old 04-02-2011, 09:15 PM   #33
kalik282's Avatar
I will close the dump valve and let black tank fill up about half way again (while holding toilet flush valve open so as not build pressure in tank) then let her rip again to a full drain then rinse hose with gray water tank.
If you can "build pressure in tank" then you have some serious problems with the venting system for your tanks!!!
John
John & Nicole
2004 Ford Excursion 6.0L 4x4
2011 Flagstaff 831FKBSS
Nights Camped: '06=122 '07=12 '08=18 '09=10 '10=18 '11=28 '12=16
kalik282 is offline   Reply With Quote
Old 04-02-2011, 09:22 PM   #34
Infractee
John
sorry, brain fart.
Fixed!
Old 04-03-2011, 01:57 AM   #35
Herk7769's Avatar
John,
I think Rodger meant "get a good flow" rather than pressure. The more full your tank is when you dump; the more likely everything that needs to come out... will.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 06-27-2011, 09:37 AM   #36
Originally Posted by herk7769 View Post
John,
So I have a 831 KRSS with the flush system but was told to never use that with the black water valve shut because it would build up pressure in the tanks. Is that inaccurate? Can I use that to fill the tank to for flushing? Right now I stand in the bathroom of the camper and gently press the foot pedal of the toilet to make the water run to fill the tank. This takes FOREVER. I would much rather just hook a hose of to the flush and let it run. Can I do that?
jim.ptak is offline   Reply With Quote
Old 06-27-2011, 10:13 AM   #37
Herk7769's Avatar
Short answer is no.
The reason is that without a way to monitor the "fullness" of your tank you can quickly overfill your black tank before you know it. Since the toilet valve is closed water will go up the vent stack and overflow onto the roof and the weight of the column of water will allow no place for the water under pressure to go. The pressure in the tank will build until a weak point (seam; pipe connection; probe hole; valve) is found and escape the tank.
You would be better served making an "extension hose" for your shower hose; remove the shower head and attach the extension hose and open the flush valve. Use the extension hose to fill the tank through the toilet. (ONLY USE IT FOR THAT and never put it IN the toilet).
That way you will see and smell when the tank is mostly full.
Old 06-27-2011, 10:51 AM   #38
I dump bottle of cheap dish soap down into tank along with couple of gallons of water before hitting the road and then empty when get set up at site. Cleans tank and seals. A friend of mine dumps a small bag of water softener down their tank along with the water. After tank drains I dump another couple of gallons down to flush and then close black water and open gray water to flush hose. I leave gray open some during stay.
Hope this helps.
real redhead is offline   Reply With Quote
Old 06-27-2011, 07:31 PM   #39
Herk7769's Avatar
Hope this helps.
I use a capful of liquid laundry or dishwash soap and a capful of Calgon Water Softener as well. I still wait till the "full" light comes on before I dump though. If Turboflush water is available I will dump at 2/3 full but never less.
black water, hose
