Old 08-05-2013, 10:45 PM   #11
Just a member
kandl's Avatar
Originally Posted by jl2you View Post
We saw a couple valves behind the panel under the sink, but try as we might, we could not turn the darned things! Didn't want to push it in case they broke off.
The valves might be stiff due to water deposits, especially if they've never been used - they typically turn only 90 degrees depending on how they were installed. If they look like this, be tender working them loose. The connection between the valve cock and ball valve is not very robust. Then you get wet...
ID:	37017   Click image for larger version
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
heater, hot water, water, water heater
