Old 09-25-2012, 09:40 PM   #1
Steve Jackson
sideout1961's Avatar
HW Heater
This is the first winter with our camper. I drained the hw tank and put the anode tube back in. My question is do I need to anything else to the tank in preparation for winter?
2011 Dodge Ram 5.7 HEMI
2011 Flagstaff Classic 29bhss
sideout1961 is offline   Reply With Quote
Old 09-25-2012, 09:45 PM   #2
Did you use teflon tape on the anode? If not, you should remove it and wrap 3 or 4 wraps of teflon on it and then re-install.
Old 09-25-2012, 09:46 PM   #3
TURBS's Avatar
Did you by pass the tank ?
Turbs
Old 09-25-2012, 09:50 PM   #4
Triguy's Avatar
You will want to bypass it by turning the three valves (sometimes two valves) so that you have shut it off from the rest of the trailer. Then you can continue to winterize your water lines using antifreeze or by blowing them out.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 09-26-2012, 04:53 AM   #5
Steve Jackson
Thanks everyone, I did all that was mentioned. So I should be all set.
Old 09-26-2012, 07:12 AM   #6
Herk7769's Avatar
Make sure the AC switch is off and stays off while power is connected to the camper and the water is gone or you will burn up your heater element in about 2 seconds.
HAM CALLSIGN - KC3FFW
Old 09-26-2012, 07:21 AM   #7
Steve Jackson
Is it even possible to get all water out of WH? I assume there will be a little left at base of tank unless you have a way to eliminate all water.
Old 09-26-2012, 08:30 AM   #8
Herk7769's Avatar
I use a paper towel that I stick in the socket hole and hang it down the side of the camper. You will be amazed how much water will wick out with a paper siphon. About 10 minutes after it stops wicking it will be bone dry inside.
DO NOT forget to put the anode back in! It will keep the threads from rusting and bugs out of the water heater.
Old 09-26-2012, 08:38 AM   #9
Steve Jackson
Thanks, great idea I will have to take care of that when I get home today.
