Old 03-26-2015, 12:58 PM   #1
HWH Inside switch
Where is the inside switch for a 2014 31RK HWH. Outside is okay but where is the inside switch?
DrippingDuo
Chappy and Liz
Dripping Springs, TX
DrippingDuo is offline   Reply With Quote
Old 03-26-2015, 12:59 PM   #2
wmtire's Avatar
Are you referring to the inside switch for the propane/dsi side of the water heater? If so, it can be by itself, or in a panel with other switches.
Or are you perhaps trying to find an inside switch for the electric heating element side of the water heater?
If you have a Suburban brand heater, this may help:
http://www.forestriverforums.com/for...ore-36197.html
2011 Flagstaff 831 RLBSS
Old 03-26-2015, 01:07 PM   #3
wmtire's Avatar
Have you checked your master panel for the propane/dsi switch to the water heater? It may just say HTR, Heater, etc. Could even just say DSI.
Looking at this video, I can't see for sure but there are most times in the panel like at the 0:40 second mark. I would see if you have a switch that has a DSI fault light beside the switch. It's explained in the link in the previous post.
Old 03-26-2015, 01:13 PM   #4
TURBS's Avatar
More often then not it's right next to the water pump switch.
Old 03-26-2015, 01:15 PM   #5
wmtire's Avatar
