Old 09-24-2019, 08:28 AM   #1
Pinn's Avatar
I found this last night
We had to replace the city water inlet and the connection behind it. We cut the hole bigger on the camper to get it all back together. And now it is pulling away from the camper. What's going to be the best way to get it fixed?Click image for larger version
ID:	215702Click image for larger version
2013 Flagstaff 27RLWS - Chloe'
2019 Ford F-250
NC
Pinn is online now   Reply With Quote
Old 09-24-2019, 08:43 AM   #2
A32Deuce's Avatar
They sell one with a bigger diameter. Don't make the hole any bigger then needed, drill small starter holes for the screws and put sealant around the opening before installing the new inlet. Looks like,you made the hole too big and did not get a good grip with the screws into the side, and I don't see any sealant!
A32Deuce is online now   Reply With Quote
Old 09-24-2019, 08:52 AM   #3
That white trim ring with 3 screws looks as if the screws are pulling away. The first thing I would think to do would be to remove the screws and apply your sealer to the back side. Then re-install it but drill 3 new holes evenly spaced between the 3 existing screw holes but out closer to the edge to find better material. This way you have 6 holes in total, 3 that are failing and 3 that move outward radially to hopefully find more solid material to anchor in to.
If the problem is what I am thinking, that the screws pulled out of the camper body material due to the cutting that you did, and the holes are damaged, you can go to a larger screw as well assuming that you can actually get a bite into solid wall material outside of that cut edge. But the addition of 3 more will share the load across all 6, and the sealant will work as an adhesive to take some additional load.
If all of that fails, you can make (or get made) a larger diameter aluminum or stainless plate to replicate the job of that one and spread the hole pattern out wider. Depending on the situation, you can make a plate that essentially captures that existing plate and sandwiches it into the wall surface, or you could make a single new larger diameter plate that replaces that factory one and cut it in half to install it and use sealant to close up any seams. You would for sure want to be sure that you use a sealer (even fill the back side with clear RTV silicone) to bond the plate to the surfaces no matter what style you build or have made. Water seepage is not your friend.
That would my first 2 methods of attacking the issue.
2017 Ram Rebel 1500 5.7L / 8 Speed, Max Tow 10,160 lb / 1,100 lb payload rating.
2019 F-150 King Ranch 3.5 Eco-Boost 10-speed, 12,800 lb / 1,680 payload.
2020 FR Coachmen Apex Ultra Lite 289TBSS
2019 Quality Trailers 16'x7' 7K GVWR Utility Trailer
2019 Iron Bull 22'x102" 14K GVWR Equipment Trailer
Larry0071 is offline   Reply With Quote
Old 09-24-2019, 03:36 PM   #4
Pinn's Avatar
All fixed now. Not factory but it is repaired Click image for larger version
ID:	215742Click image for larger version
2019 Ford F-250
NC
Old 09-24-2019, 03:48 PM   #5
Well... that should hold!
Thanks for reporting back with your fix.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 09-24-2019, 03:52 PM   #6
Brake is on left
The Evil Twin's Avatar
Glad to see you got it repaired. I was going to suggest a sheet of white acrylic about 1/4 inch thick. Cut to size so much like the material you used.
The Evil Twin is offline   Reply With Quote
Old 09-24-2019, 04:00 PM   #7
cboss's Avatar
Thanks so much for posting the fix. We often don't get to see the happy or sad endings to issues posted.
Craig & Cath
2018 2902WS Rockwood Ultra Lite
2017 Ford F250 Lariat, 6.2 gas
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2016(retirement): 669
cboss is online now   Reply With Quote
Old 09-24-2019, 04:21 PM   #8
keith52's Avatar
Looks good from here!
2014 Chevy CC Duramax 4X4 Long Bed
2017 Cedar Creek 36CKTS
MORryde independent suspension with disc brakes
keith52 is offline   Reply With Quote
Old 09-24-2019, 06:40 PM   #9
Function is often more important than form.
Looks good from where I sit.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 09-25-2019, 02:17 PM   #10
B Mac
I had a similar problem and used 3 toggle bolts. They expanded behind the wall and provided enough bite to hold it in place.
bbbymac is offline   Reply With Quote
Old 09-25-2019, 03:25 PM   #11
Air Force Retiree
To help eliminating this problem, by removing water hose stress, get a 90 degree hose attachment elbow for attaching FW hose to camper.
Retired Air Force is offline   Reply With Quote
Old 09-25-2019, 05:31 PM   #12
One can also get "Pop Rivets" that use a threaded mandrel to expand them. Insert, expand, then remove mandrel and use machine screw to secure fixture. Some thick sealer behind it too.
Just another method.
2004 Nissan Titan
Old 09-25-2019, 06:52 PM   #13
Carknocker Family
Ida Ratherbe Camping's Avatar
You mean like the one posted in pic? Twice?
Or is there something else?
Ida Ratherbe Camping is online now   Reply With Quote
Old 09-25-2019, 07:38 PM   #14
Those are also called "rivet nuts" or "riv nuts". Available in aluminum or steel.
Larry
Larry-NC is online now   Reply With Quote
Old 10-07-2019, 06:23 PM   #15
Thumbs up
Looks Good!!
Old Willie is offline   Reply With Quote
Old 10-07-2019, 06:29 PM   #16
CaptnJohn's Avatar
In a wet environment I'd use Starboard. Not cheap but best product. Used on boats. Available at marine supply and Lowes.
2019 Montana 3761 FL
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
Old 10-08-2019, 11:01 AM   #17
Found this last night
Glad you have a fix. For others and future reference there are a couple of solutions that are quite easy. One, if you are handy with wood, make donut out of 1/2 inch plywood where the inside diameter matches your desired hole opening and the outside is at least 1/2inch larger all the way around than the opening. Cut the donut in half, slather it with adhesive poke through the hole and pull it up against the inside of the wall. Do the same with the other half. Wait for the adhesive to set and then you have some backing to screw into. Alternatively you can go to the automotive store and by the clip on fasteners that are designed for either sheetmetal screws or machine screws. Align them with the existing holes. These are designed to slide over sheet metal so you have to find one that is deep enough to accommodate the roughly 1/4 inch thickness of the sidewall.
colretired is offline   Reply With Quote
Old 10-09-2019, 12:19 PM   #18
If you still have enough material behind the plate you could try installing well nuts instead of screws. Well nuts (link provided below) require a larger hole for installation but expand behind the mounting material with a rubber sleeve, similar to other expansion-type anchors but not requiring particularly deep mounting space as with mollie bolts or plastic anchors. They will be available at Lowes or Home Depot and some Ace stores in their hardware - specialty fasteners.
MisterVick is offline   Reply With Quote
