01-30-2015, 06:26 PM
Love My Sunseeker
I may have done something STUPID with water heater....
I just picked up my RV from being in the shop 3 weeks for a stress crack repair. Sunseeker 3170.
I had the dealer winterize the system before sending to the body shop for repair. So, NO water was in system.
Ok, I get to RV park. I filled up my water tank. Here is where the stupidity went in.
I turned on the water heater BEFORE I pressurized the system. I think the water heater was on about 30 minutes before I ran water through it.
I realized this, and turned water heater off, and just ran water cold through the system.
Am I going to start seeing problems with my water heater? Due to stupidity?
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
01-30-2015, 06:33 PM
Unfortunate event. Water heater on with no water, element probably toast. I think it needs water to keep the element from burning up. Usually not a very expensive repair. Can happen to anyone, especially when you get in a hurry. Let us know how it works out.
Chuck "still in Va "
If "was on" means the electric side was on and not just the propane system, you have ruined your electric heating element. If you are talking about running the propane system only, you may have a different problem.
01-30-2015, 06:43 PM
I did the exact same thing last weekend-forgot that I had purged all the water out of the water heater. I only have propane so it turned on for about ten minutes then I heard steam coming from the pressure valve. Added water to the heater and flipped switch and nothing. Removed outside panel and pressed reset button and it fired up and all was good.
Hope yours is just as easy.
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
01-30-2015, 06:54 PM
As mentioned above, If you turned on the electric side of the water heater and you were connected to shore power ( 110VAC) you burned out the heating element. It takes less than a few seconds. You can still use the WH on propane. Replacement element is relatively inexpensive, parts lots less than labor.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
01-30-2015, 08:09 PM
Love My Sunseeker
Ok, I know an RV dealer that does service on Saturday, so I have an appointment for tomorrow.
01-30-2015, 08:31 PM
It's an extremely easy and inexpensive fix. Watch how they do it so you feel comfortable making the repair yourself. It's always a good idea to pull your electric anode at least once a year for inspection and flushing the tank anyway.
No permanent damage done.
01-31-2015, 10:02 AM
Love My Sunseeker
So it's the anode rod they have to pull? Aw man, I had the RV dealer in Chehalis (where the body shop was) replace the anode rod.......
01-31-2015, 10:25 AM
You need to replace the heating element, not the anode rod. That is what burned out when you ran it with no water. The heating element is what heats the water. The anode rod is simply a sacrificial rod that prevents corrosion of the HW tank. In the attached photo. The rod on the left is new. The rod on the right is totally gone. I would not wait to get to the point where mine looked like the one on the right. The anode rod should be checked once or twice a year depending on the water quality. They are very simple to replace as you simply remove it and if needed, screw in the new one.
TST Tire Monitors
2 100W solar panels
01-31-2015, 10:29 AM
View this video for info.....
Fonzie
01-31-2015, 10:38 AM
Unfortunately, yes. New or old, it only takes a couple of breaths to toast an anode when no water is present. Most of the time all it takes is a new rod... $20 bucks and 10-15 minutes.
If it was on for 30 minutes, and changing the anode does not provide hot water, then it's possible the temp relay could have been damaged as well. But that's only another $10 and 5 minutes. Again.. no long term damage with a fired relay either.
Point being.. if you are taking your rig in to have it done for you, don't let them just change out your anode and send you on your way. Make sure you are getting hot water before you leave.
Most of all, this falls under the "little things" category.. don't sweat it. I know more than a few very seasoned full timers that have done the same exact thing.. repeatedly! Not me of course (whistling casually to the side).
01-31-2015, 10:42 AM
Yarome, not to confuse OP, it is the electric "element" that needs replacement and not the "anode"....
Fonzie
I don't know why these facts are so HARD to comprehend... but it seems like someone furthers the misconception every month that the anode rod is the "heater" or they are mad that the anode rod is metal with a metal threaded end instead of plastic.
01-31-2015, 10:59 AM
fonzie, thank you for posting the video. Very useful.
2013 Rockwood Mini Lite 2109S
2006 Dodge Durango Hemi 5.7
Equal-i-zer WDH
01-31-2015, 11:03 AM
The electric element and the anode rod are often confused on the Suburban water heater (as well as the terminology for the two) since they are almost side by side on the heater.....even though they are two total different things.
The easiest way to remember, is if it has electric wires going to it, it's the electric heating element. You usually have to remove the gas flue pipe and then a cover to access the heating element.
No Wires, then it's the sacrificial anode rod, that is what you also remove to drain the water heater. This anode will also need periodic replacement, as it "sacrifices" itself so the tank won't rust out. That's the reason the rod is used at the drain location, so you can keep your eye on it each time you drain the heater, to see if it needs replacing.
As far as replacing the electric heating element, KyDan has a great tutorial with pics, in our FAQ section:
http://www.forestriverforums.com/for...d-r-50292.html
EDIT: I took and edited one of Dan's pics for his tutorial above, to show the location of the electric heating element and anode rod. The gas pipe has already been removed in the pic.
2011 Flagstaff 831 RLBSS
01-31-2015, 11:29 AM
AKA: 'tiredTeacher
Not necessarily true. I made this mistake and my element survived 20 minutes before I filled the WH. it has worked fine for a year now.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
01-31-2015, 11:51 AM
I burnt out the electric element on my previous trailer. It was an easy fix once I got the old element out. Extracting the old element, even with the correct tool, was a tough job that required a lot of brute strength to start the turn and without being too heavy handed where I would have caused further damage to the side of the trailer. Lesson learned. I now always make sure I have water in the tank before adding the power.
Richard & Diane
2014 Cedar Creek 38FL
2016 F350 Lariat CC DRW
Retired Metropolitan Police (UK)
Have both the heater element and anode replaced and the tank flushed, one stop all done!
01-31-2015, 12:42 PM
DX are you getting hot water? I would try it before I went through the hassle of changing it.
2013 Berkshire 390BH
01-31-2015, 01:06 PM
Don't feel bad. Been there, done that!
VMI'62
