Old 01-30-2015, 05:26 PM   #1
Love My Sunseeker
DXSMac's Avatar
I may have done something STUPID with water heater....
I just picked up my RV from being in the shop 3 weeks for a stress crack repair. Sunseeker 3170.
I had the dealer winterize the system before sending to the body shop for repair. So, NO water was in system.
Ok, I get to RV park. I filled up my water tank. Here is where the stupidity went in.
I turned on the water heater BEFORE I pressurized the system. I think the water heater was on about 30 minutes before I ran water through it.
I realized this, and turned water heater off, and just ran water cold through the system.
Am I going to start seeing problems with my water heater? Due to stupidity?
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
DXSMac is offline   Reply With Quote
Old 01-30-2015, 05:33 PM   #2
Charles Firth's Avatar
Unfortunate event. Water heater on with no water, element probably toast. I think it needs water to keep the element from burning up. Usually not a very expensive repair. Can happen to anyone, especially when you get in a hurry. Let us know how it works out.
Chuck "still in Va "
Charles Firth is offline   Reply With Quote
Old 01-30-2015, 05:33 PM   #3
Mr. Dan's Avatar
If "was on" means the electric side was on and not just the propane system, you have ruined your electric heating element. If you are talking about running the propane system only, you may have a different problem.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 01-30-2015, 05:43 PM   #4
HONDAMAN174's Avatar
I did the exact same thing last weekend-forgot that I had purged all the water out of the water heater. I only have propane so it turned on for about ten minutes then I heard steam coming from the pressure valve. Added water to the heater and flipped switch and nothing. Removed outside panel and pressed reset button and it fired up and all was good.
Hope yours is just as easy.
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
Old 01-30-2015, 05:54 PM   #5
Flybob's Avatar
As mentioned above, If you turned on the electric side of the water heater and you were connected to shore power ( 110VAC) you burned out the heating element. It takes less than a few seconds. You can still use the WH on propane. Replacement element is relatively inexpensive, parts lots less than labor.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-30-2015, 07:09 PM   #6
Love My Sunseeker
DXSMac's Avatar
Ok, I know an RV dealer that does service on Saturday, so I have an appointment for tomorrow.
Old 01-30-2015, 07:31 PM   #7
It's an extremely easy and inexpensive fix. Watch how they do it so you feel comfortable making the repair yourself. It's always a good idea to pull your electric anode at least once a year for inspection and flushing the tank anyway.
No permanent damage done.
rana is offline   Reply With Quote
Old 01-31-2015, 09:02 AM   #8
Love My Sunseeker
DXSMac's Avatar
So it's the anode rod they have to pull? Aw man, I had the RV dealer in Chehalis (where the body shop was) replace the anode rod.......
Old 01-31-2015, 09:25 AM   #9
Flybob's Avatar
You need to replace the heating element, not the anode rod. That is what burned out when you ran it with no water. The heating element is what heats the water. The anode rod is simply a sacrificial rod that prevents corrosion of the HW tank. In the attached photo. The rod on the left is new. The rod on the right is totally gone. I would not wait to get to the point where mine looked like the one on the right. The anode rod should be checked once or twice a year depending on the water quality. They are very simple to replace as you simply remove it and if needed, screw in the new one.
TST Tire Monitors
2 100W solar panels
Old 01-31-2015, 09:29 AM   #10
fonzie's Avatar
View this video for info.....
Fonzie
heater, water, water heater
