Old 01-09-2018, 11:14 AM   #1
I messed up..........
I made a stupid mistake on our trip back from Florida. I had winterized the camper when we were in Florida. On the way back the temps were in the low 30's so I decided to put a few gallons in the FW tank and just run the toilet. Left everything else "sealed". It got very cold on the 2nd night but the water was still working fine and the tank heaters were doing their thing. on the last leg and then the first night at home it dropped to single digits.
My intention was to re-winterize when we hit Maryland but because the temps were in the single digits for days the pump froze solid. I kept the furnace running but apparently it is not ducted to the front compartment where the pump is and since I did not have the HW heater on it stayed cold. I figured this out later In hindsight I should have either de-winterized completely or not at all!
Now, I am waiting for the temps here to moderate a bit to assess my stupidity induced damage.
I'll let you know how it turns out.
Marty
2016 Rockwood 2703WS Sapphire
2016 F250 SD 6.2L
Martsing is offline   Reply With Quote
Old 01-09-2018, 11:49 AM   #2
MillMitch's Avatar
Good luck! I suspect, with this artic air up north, a lot of us are going to be second guessing our winterizing procedures. First time winterizing for me last fall, and I did it twice. First time without opening the low point drains. Had an 'oh crap' moment after reading posts and went out to storage facility and redid it. This forum is awesome.
Mitch in MN
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
MillMitch is offline   Reply With Quote
Old 01-09-2018, 11:58 AM   #3
Next time, just get a couple jugs of water and flush the toilet with the water jugs.
2011 Traverse LT, 3.6L, FWD
Old 01-09-2018, 12:51 PM   #4
Oh.... my.... God.....
I have you guys tell people that in the past and it never freakin occurred to me.
Marty
2016 F250 SD 6.2L
Old 01-09-2018, 01:39 PM   #5
Martsing, sure you are not the only one having this problem. What's really concerning is all the posts talking about water pumps freezing up in a compartment that is supposed to stay warm enough to not freeze. It only has to stay above 32 deg.
Good luck, let's hope no major pipe damage, the pump is easy to replace.
Rich5117 is offline   Reply With Quote
Old 01-09-2018, 07:35 PM   #6
I hear you, but to be honest I can't fault the unit. If I would have dewinterized completely then the water heater would have kept that area warm. As it is, I only halfway dewinterized and that compartment was left to fend for itself! A lesson learned.
Marty
2016 F250 SD 6.2L
Old 01-09-2018, 07:45 PM   #7
Just from experience....Rv's were not engineered to be lived in. The lowest temp most Rv's are said to withstand is 25 degrees. I've seen them be ok in colder but manufacturers recommend that you not stay in them past 25 degrees. Too many things start going wrong or act up due to the cold weather.
trailer tech is offline   Reply With Quote
Old 01-09-2018, 10:21 PM   #8
Thurman's Avatar
Also from experience: We were in Ochlocknee Bay, FL. Thu-Sun last week. Thursday night's low was 23° with a light wind coming off the Bay. My furnace was set to 66° and could not keep the TT that warm. We supplimented with an electric space heater and two quilts, well maybe a little snuggling too.
2015 FR Freedom Express 310BHDS pushing a 2014 GMC Sierra CC
Thurman is offline   Reply With Quote
Old 01-11-2018, 12:13 PM   #9
Update!
I dodged a bullet. The temps moderated and the pump stated working. I quickly re-winterized the system and noticed no leaks when pressurized.
I am going to go ahead and buy a new pump anyway and keep it as a spare.
Phew.
Marty
2016 F250 SD 6.2L
Old 01-11-2018, 12:38 PM   #10
Phew.
Marty
Good deal,you just hit the "RV Lottery"! Youroo!!!
