Old 07-18-2012, 06:35 PM   #11
TURBS's Avatar
iv e used a long pair and come in from the right side of the hw heater switch behind tube with great success .
Old 07-18-2012, 06:42 PM   #12
B47
Originally Posted by funkyJunk View Post
And I replace my anode rod every year as well. Keeps your water system from getting fouled. I think those take a 1 1/16 socket.
That is the size ny Suburan WH anode rod takes.
Old 07-18-2012, 06:47 PM   #13
B47
Originally Posted by GlacierGus View Post
... I've been wanting to ask. How do you get the pin back into the switch? The switch is behind everything and I cannot get an open shot at the tiny pin hole. How do you get this accomplished? My unit is a Suburban. Thanks.
The pin can be inserted - just takes a little twisting, turning and holding your mouth just right
If you can't get the pin in, I suggest getting a lenght of wire and bending it so you can get behind the lines and into the hole. This will serve the same purpose as the pin - just a reminder that you need to check for water in the WH before flipping the switch on.
Old 07-18-2012, 06:49 PM   #14
B47
Originally Posted by youroo View Post
I am with you Gus,once you get that little (igogho8w) pin out I never want to put it back in! Youroo!!
And if you don't insert the pin you might be having the same experience as smallstonefan and several others have had.
Old 07-18-2012, 06:50 PM   #15
TURBS's Avatar
which way you hold your mouth then ?
Old 07-18-2012, 07:00 PM   #16
I leave the pin out of mine and I installed a switch inside with a red light. I turn the wh on and the light is red off and no light. Is an easy mod the water heater plugs into a receptical and you switch the receptical.
Bill And Theresa Perry, At Lake Gaston
2004 R Vision Trail Lite
2003 F 150 Super crew with 5.4 Tow package
bill and theresa is offline   Reply With Quote
Old 07-18-2012, 07:00 PM   #17
B47
Well that depends on where you are located and what time it is!
Old 07-18-2012, 07:02 PM   #18
Thank you very much for the advice,I will go buy a clip and put it in right away. Youroo!!
Old 07-18-2012, 07:08 PM   #19
B47
This would as a good secondary warning IMHO. However, I still like the pin method - a simple mechianial method - if the pin is in then you are reminded that something needs to be done/checked before proceeding.
Old 07-19-2012, 09:50 AM   #20
smallstonefan's Avatar
Thank you everyone for the info! I will find the wattage I need and get this done.
MUCH appreciated!
smallstonefan is offline   Reply With Quote
