Old 05-22-2014, 08:59 AM   #1
sammonilla's Avatar
ice in black water tank
Anyone heard of this?? My sensor always says that my black water tank is 3/4 full even when empty. I have taken it into the dealer several times and it has not been fixed. We are very carful not to put anything in the tank but for the proper paper. I did hear that I can put ice cubes in the tank right before I tow and it will clean the tank and the sending unit. Has anyone tried this?? It sounds like it would work with the ice sloshing around but I don't want to damage the sending unit?? Any input?? Or any other idea's??
Scott Sammons
Woodinville Wa
GO SEAHAWKS!
2016 SILVERADO 2500HD 6.6 Duramax
2012 280BH Casscade
sammonilla is offline   Reply With Quote
Old 05-22-2014, 09:04 AM   #2
Soxfan1957's Avatar
I do it all the time. It won't damage anything.
Sent from my DROID RAZR HD using Forest River Forums mobile app
Soxfan1957 is offline   Reply With Quote
Old 05-22-2014, 09:05 AM   #3
Look up the GEO method. You use water softener and detergent instead of store bought stuff. It really cleans and keeps stuff from sticking.
Enconcapt is offline   Reply With Quote
Old 05-22-2014, 09:05 AM   #4
LittlePM's Avatar
We have an ice maker in our GT and when we are closing up we dump the ice in the toilet. Some people will tell you to dump the ice and drive around the campground then dump.
Pennie and Chuck, Mandi and Polly (the little dogs)
Hosted BamaGanza 2017 & 2018
2014 Georgetown XL378, 2014 GMC Acadia Denali Toad
The Home of the FREE because of the BRAVE
LittlePM is offline   Reply With Quote
Old 05-22-2014, 09:12 AM   #5
sammonilla's Avatar
What kind of detergent do you use? Just drop a few packets of laundry soap down the drain?
Scott Sammons
Woodinville Wa
GO SEAHAWKS!
2012 280BH Casscade
Old 05-22-2014, 09:35 AM   #6
I use the GEO method. I use about a cup of Dawn soap and Borax powder... the soap cleans the grease type stuff and the borax cleans removes minerals etc I use about cup to 2 cups borax No odor and nice clean tank
Jerry. Vietnam vet.
Retired
jgahlhoff is offline   Reply With Quote
Old 05-22-2014, 09:37 AM   #7
BTW I use the Borax as sometimes water softener is hard to find
Jerry. Vietnam vet.
Retired
Old 05-22-2014, 06:41 PM   #8
I've put dishwasher detergent (no suds) with 7 - 10 gals of fresh water into our tanks every year on our 2nd to last night out and then about 7 - 10 gals of fresh water on our last night out every year we've been snowbirding. Our tank gauges have worked (almost) all the time. Good luck.
The_Painting_Teacher is offline   Reply With Quote
Old 05-22-2014, 07:04 PM   #9
Simple, easy and effective...after you dump...put a few gallons of water in the tank and drive home.
Empty with a bucket once your home and throw it on your lawn.
Works good for us on our 3 previous trailers...always showing empty on sensors .
Black
Black is offline   Reply With Quote
Old 05-22-2014, 07:54 PM   #10
Timex's Avatar
In the mid 90's here today. I'd never make it out of the campground before that ice melted!
If, I were camping now.
Timex is offline   Reply With Quote
Old 05-22-2014, 08:05 PM   #11
Road-King's Avatar
X2. I haven't had a problem since I went to this method. The only time my black tank is dry is after I winterize my unit.
After I dump I add 1/2 cup Calgon, 1/2 cup dollar store plane liquid laundry detergent in 5 gallons of water to the black tank. Here K-Mart carries Calgon. 1 box last a season for us.
Sent from my SCH-I535 using Forest River Forums mobile app
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 05-24-2014, 01:54 PM   #12
I had the same problems with my sensor. It read 2/3 full when empty. Put about 3 gallons of water 2 small bags of ice, drove a while, still didn't work. 2nd attempt, 3 gallons water a cap or two of cascade. Checked it before dumping, still didn't work. After dumping filled the tank (visual check) and dumped tank. Then it worked. Figure there was something stubborn on the sensor. Think the ice, and cascade loosened or softened whatever was causing the problem but the second full tank clear water flush did the trick....Hope it works for you.
kamu is offline   Reply With Quote
Old 05-27-2014, 06:34 PM   #13
sammonilla's Avatar
Thanks for all of the imput. I loaded it up with sone water and detergent and the gauge was working properly when I got to the campsite. After the long weekend and dumping the tank it now still shows 2/3 full. Has anyone installed a tank cleaner like a tornato?? If so how easy was it???
Scott Sammons
Woodinville Wa
GO SEAHAWKS!
2012 280BH Casscade
Old 05-27-2014, 06:40 PM   #14
Herk7769's Avatar
FYI - Gray tank problems can usually be traced to hair and soap.
Black tank problems are almost never TP (the probes are almost flush with the wall). Slime will form on the walls shorting the probes to ground.
I fixed mine like this:
http://www.forestriverforums.com/for...tml#post129030
RV Holding Tank Sensors - Get accurate grey and black holding tank monitor readings
More than you will ever want to know about holding tanks:
https://www.google.com/search?q=gray...iverforums.com
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 05-27-2014, 06:48 PM   #15
I have put ice in black tank many times and drove home....no problems and works well. I also use the geo method
2012 F350 Lariat CC SRW 6.7L Powerstroke
pwrstroke2012 is offline   Reply With Quote
Old 05-27-2014, 06:58 PM   #16
Ford Idaho's Avatar
Five or eight pound bag, pour the ice toss the bag make it the very last thing you do.
Old 05-27-2014, 07:29 PM   #17
SKnight's Avatar
I stop at one of those stand alone ice machines you see today and get the coolerfull load of ice. Pour that in with roughly 1/3-1/2 tank of water and tow it. The ice gently scrubs the walls but doesn't hit anything hard enough to damage it.
If you're going camping again soon you can toss a sanitizer pack in to keep that from smelling, if not then find somewhere to dump it and do your regular sanitizing.
Old 05-27-2014, 07:47 PM   #18
Evereddie's Avatar
This is a very important point. The slime hangs to the walls and is conductive. The sensors think it is the water level and turn on. Clean walls don't give false readings.
Evereddie is offline   Reply With Quote
Old 05-28-2014, 02:02 PM   #19
sammonilla's Avatar
Thanks for all of the input from everyone. I'm still having some issues with the sensors but it looks like I need to pull them out and check to see the condition of them.
Scott Sammons
Woodinville Wa
GO SEAHAWKS!
2012 280BH Casscade
black, black water, tank, water, water tank
