Old 07-11-2016, 08:43 PM   #11
NMWildcat's Avatar
Originally Posted by spock123 View Post
I think the tankless water heater takes the same amount of time
X2. We boondock a lot and we use the same amount of water as we did in our old RV with a tank.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 07-12-2016, 01:24 PM   #12
Does your tankless work the same if you are on your 12 volt water pump or if you are at a campground that has low water pressure. I know they work great in a house because the water pressure is always the same. I have a 12 gallon hot water heater in now but if I couldn't get the tankless to work for me I could not replace it with another 12 gallon. It would be a smaller one
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 07-12-2016, 01:32 PM   #13
NMWildcat's Avatar
The tankless works great on the pump. If we are at a CG that has very low pressure we just fill the fresh tank and use the pump. Only had to do that once so far. We really enjoy the tankless, especially when we have the grandkids. And when at a CG, the long showers are excellent
Old 07-12-2016, 01:35 PM   #14
BandJCarm's Avatar
Spock, interesting question.
One of the suggestions a guy made at the CC site, while I was camping, was to get off of city water and go on FWT with pump. Voila, sounded great. So I did..........filled the FWT and turned on the pump.
It will not even work with the pump. Period. Water flows out of tap, and about 1 minute later the DSI/FLT light comes on, 100% of the time. It won't light (or won't stay lit, whichever the FLT light actually means). So I have no idea if it actually produces hot water with the pump should it stay lit!
I will say this........that the FWT and the pump did not produce very high pressure water, even cold.........and I took the regulator out of the loop about 2 hours into this process, so it never was in the line during all the trouble.
NM suggests that the HW Tankless unit is faulty. He may be correct. I languished long and hard over the CC offer to replace it with a conventional one. But in the week after the offer was made, I read no less than 12 online complaints from fellow folks with tankless heaters, and every one was about to pull their hair out. Couple that with the fact that CC made the offer of replacement without even bothering to suggest a repair of the tankless. Their email basically said "Yeah, we tried this Suburban tankless thing and sometimes new stuff just doesn't work out". SO, I believe they know/knew it was going to be dicey keeping this thing working. We're in it for the long term, and a conventional, dependable heater is just too good of an offer to pass up.......especially since it'll be done by factory techs at Goshen, not any dealer.
I know NM and another friend of mine (with the exact same unit) love their tankless units. I would wonder, however, if they have not 100% of the time camped where the pressure is constant and high??? Mine worked (so/so) at the Nashville Jellystone park I was at for one night, because pressure was good. That made me think that most of the complaints, including mine, are at random sites....which is where I'll be rest of my camping life, so.............replacement just seems prudent.
FROG AR-0019-242
BandJCarm is online now   Reply With Quote
Old 07-12-2016, 01:42 PM   #15
The same thing happened to us with a new TT several years ago. Water was hot for about 5 seconds then it went cold. It turned out that a bypass valve was open when it should have been closed. It allowed cold water to mix with the hot water as soon as it left the water heater. The same thing happened to a couple more people on here. May want to check the position of your valves.
LarryInNC
2015 Flagstaff V-Lite 30 WIKSS
2016 Chevrolet Silverado 2500HD 6.0L
Days camped in 2015: 35
Days camped in 2016: 58
LarryInNC is offline   Reply With Quote
Old 07-12-2016, 01:45 PM   #16
BandJCarm's Avatar
Thanks, Larry. I had a lot of things wrong on Day One with my issue. But I was posting here (via phone, with one bar!! LOL) and getting great advice. I followed it all and did fix some of the things that should have been obvious to fix things, including that. Heck, I had a long thread going, with pictures. The folks here were great........even though I felt frustrated and moronic.
But in the end, after ALL obvious fixes were done, it made no difference. It did the same thing. Then it worked sorta ok at the next campground (one night). I realized then that "sorta ok" was probably going to be the best I ever got. That's when I emailed CC Warranty, and then I got the offer of replacement, which is where we're at.
FROG AR-0019-242
Old 07-12-2016, 01:46 PM   #17
NMWildcat's Avatar
BandJCarm, sorry you have had such a bad experience. Sounds like a switch to a tank will get you fixed right up. Good luck and I hope you have no more problems!
Old 07-12-2016, 01:50 PM   #18
2016 Sandstorm here. Just had a recall done on our tankless hwh. Would get hot then really hot and blow breaker in tank. Fixed for now. It has an Atwood unit. Still un decided on if we like it better than a tank or not.
guyster is offline   Reply With Quote
Old 07-12-2016, 01:52 PM   #19
BandJCarm's Avatar
I have to admit, the CONCEPT is awesome.
The execution is not.
Sorta like Razorback football the last 20 years............
FROG AR-0019-242
Old 07-12-2016, 02:10 PM   #20
NMWildcat's Avatar
I'm sorry your experience has soured you on tankless, but in all fairness there are quite a few of us that really enjoy the new concept and will insist on tankless for our next RV. So not all tankless installs are problematic.
I'm usually not one to dive into new concepts right away. But this one we like.
Now, the new concept of residential fridges in RVs just makes no sense to me.
