Old 01-17-2016, 09:06 AM   #11
AquaMan's Avatar
Have never had the antifreeze stain anything. The toilet and shower "stains" are usually gone by the time I'm done flushing the system out.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 01-17-2016, 12:59 PM   #12
Try Mr. Clean Eraser.
DTraband is offline   Reply With Quote
Old 01-17-2016, 02:09 PM   #13
Thumbs up
Originally Posted by tdst51 View Post
A couple of weeks ago I put a little RV anti-freeze in the all the traps in the trailer, and thought I would put just a little in the toilet. Checked it the other day, and it had leaked past the seal, which doesn't bother me, but now the toilet is stained bad! Pink or orange or whatever that color is. Any ideas on how to get that cleaned out? Do I dare use a little bleach in some water, or is that a no no? The toilet is porcelain; I'm wondering if that is going to be any easier as compared to some of the plastic ones. I'm very very lucky- my wife doesn't read the forums. Thanks in advance for any suggestions!
If I was you, I would be more concerned about the interaction between antifreeze and bleach in the tank.
Don't worry! We have a porcelain toilet and the antifreeze stains goes out every spring, when we flush the system with water!
Grangalo
2014 Rockwood Windjammer 2809W Diamond package.
grangalo1812 is offline   Reply With Quote
Old 01-17-2016, 02:53 PM   #14
Toilet Stain
We have a porcelain unit in our travel trailer and we only use a powdered cleaner that we get from the RV dealer and it works real well. I would not mix the bleach with the anti-freeze just in case of some kind of nasty chemical reaction.
2008 GMC Sierra 2500 Heavy Duty
2015 Flagstaff 34' Lite
NWT Rick is offline   Reply With Quote
Old 01-17-2016, 04:53 PM   #15
nodrawers's Avatar
Just curious. What brand of anti-freeze did you use?
Tom & Laura USAF Ret Smsgt
1995 2500 5.9 Cummins 5 sp 3.54 diff
2011 Coachman Catalina 22FB
Days Camped 2016 91, 2017 110
nodrawers is offline   Reply With Quote
Old 01-18-2016, 11:21 AM   #16
One plus with porcelain is on bad stains or build up you can use 1000 or 2000 grit wet/dry paper and can sand it. Will take built up items like hard water calcium off and polish the porcelain at same time. Cant do this on fiberglass or plastic for obvious reasons. I got this info from American Standard.
j free is offline   Reply With Quote
Old 01-18-2016, 12:04 PM   #17
tell me why would u leave antifreeze in the toilet bowl?????/
Gee Whiz is offline   Reply With Quote
Old 01-18-2016, 12:10 PM   #18
TURBS's Avatar
I'm in BIG trouble!
To keep the seal soft and pliable.
Also to help form a better seal.
Same reason you leave water in the bowl.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 01-18-2016, 02:08 PM   #19
Will it ever come clean?
You have two things going on here;
1) the stain, and since you said the bowl is porcelain you will have no problem, i would stay away from "bleach" as that has a chance of making you situation with the bowl seal worse (bleach can damage the rubber plumbing parts) so just use a bowl cleaner (if it does not just flush away) and in most cases it will.
2) having a panic attack over something you did "correctly" you were suppose to add the antifreeze to your water system but you and all others need to stop and take a deep breath, as if you are suppose to use a product every year to protect your water system, "why" would it be made and stain all it touches? It will not leave a permanent stain in most cases and in something as hard as porcelain you should always be ok.
Hope this help and in the end Happy Camping
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
Old 01-18-2016, 02:57 PM   #20
rracer5's Avatar
What's your number.....I'll call her & let her know...
Seriously......NO BLEACH....as mentioned in will damage the bowl seal & once in the tank could damage your dump valve seals.
A little cleanser on a sponge should get it right off.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
