Old 05-16-2016, 03:51 PM   #11
Head Rambler
The issue with using a hot water faucet on an RV to check if the tank is full is that if the unit is left in the winterized position you'll get plenty of water out of the faucet and the hot water tank will be completely empty. That's why you'll see plenty of recommendations to open the T&P valve on RV water heaters.
Gotta go campin!
Old 05-16-2016, 03:54 PM   #12
jtownstumpjumper's Avatar
Location: Jonesboro AR--Home of Arkansas State University and the Red Wolves
Also be careful opening the relief valve if it's been heating water....you can get burned!!!...don't stand in front of it...stand off to the side.
Lloyd & Kathy & Kit(19 yr old cat)
2018 Forest River Palomino Columbus 383FB
2016 Chevy 3500HD SRW Z71 LTZ 4WD Crew Cab, DuraMax/Allison.
2014 - 38 nights/3500 mi.; 2015 - 66 nights/6260 mi.; 2016 - 44 nights/6106 mi.
2017-65 nights/6992 mi.; 2018-7 nights/1037 miles....9 nights booked
jtownstumpjumper is offline   Reply With Quote
Old 05-16-2016, 04:12 PM   #13
wmtire's Avatar
Originally Posted by bsmith001 View Post
I am a plumber, so don't open the relief valve on the water heater. If som trash gets in it the valve will leak. Open a hot water faucet to bleed the air or check if you have hot water
Howdy bsmith001, I am kinda curious about this comment from you being a professional plumber. I can certainly understand how many times ya probably are called out due to a leaking pressure relief valve...... but since it IS a safety device, shouldn't it be tested at least yearly to make sure it isn't faulty?
If you never open it, then how do you know it's not seized up, and thus would fail to open if need be?
I would think that at least opening up your pressure relief valve once a year (as when dewinterizing your RV) would be a prudent thing to do to make sure the safety device could function if needed....and as Bama Rambler explained, if your bypass/crossover valve is incorrect, opening the faucets aren't a sure sign that there is water in the heater.
I know my Rheem water heater at my house recommends testing the pressure relief valve TWICE a year, as the function is fully explained in their article below:
http://www.rheem.com/docs/FetchDocum...3-710821ace0dd
These are just my thoughts on the subject and your mileage may vary.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 05-16-2016, 04:42 PM   #14
B and B's Avatar
X2 when winterizing i open the valve to drain the tank, never with hot water present.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 05-16-2016, 09:20 PM   #15
You sure can open it but I would have a spare just in case it would start leaking
bsmith001 is offline   Reply With Quote
Old 05-17-2016, 06:46 AM   #16
KyDan's Avatar
The original poster has not returned so we hope he got his answer!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 05-17-2016, 08:59 AM   #17
Originally Posted by elrand View Post
we have all been the new person at one point or another. dont worry about asking questions. We would rather you enjoy and relax then get frustrated of a simple problem
X2
brewjaz is offline   Reply With Quote
Old 05-17-2016, 09:28 AM   #18
gettawaydriver's Avatar
All new at one point
Test the pressure relief valve on the hot water tank to check for water. If it does not seal when you release it then test it again a piece of debris may be in the valve and the second test should dislodge the debris or a third or fourth time. The problem comes when people open the valve to drain the hot water tank faster. It will vacuum oxidation from inside the valve into the assembly.
Also be sure to check the drain plug. It is a hex head looking plug (1 1/8" ~) it may be plastic or metal and possibly have a sacrificial anode on the inside of it. If all is good start the heater and watch for leaks. If something leaks, cool the tank and repair the leak.
On a side note be sure to have a pressure regulator on the city water connection and DO NOT run your pump if tied to city water, it will destroy the pressure switch and possibly the pump as well.
gettawaydriver is offline   Reply With Quote
Old 05-17-2016, 11:01 AM   #19
Tom48's Avatar
That has been my experience as well. Wound up replacing a 40 WH last year when a presure relief valve started leaking and could not be removed and replaced due to design. DW can open a hot water faucel while I run around doing outside setup stuff.
Tom48 is offline   Reply With Quote
Old 05-17-2016, 03:37 PM   #20
KyDan's Avatar
OK we have to remember this is NOT a 40 year old WH. It is a new RV water heater. The ONLY way to be SURE the WH is full of water is to open the safety relief valve and check for water. Any other way does not make sure the tank is full. Opening a hot faucet gets water but did it come from the HW tank or BYPASS the tank??
Pull the safety valve. Let it snap shut. IF it drips- pull and let is snap
again. If it drips and repeated flush and snap do not stop it you can replace it. That is highly unlikely on a new or late model RV.
As we all know turning on the 120v AC to an empty water heater is instant death to the heating element.
Peace!
Dan & Rita D
Blue Ox WD hitch
newbie
