Old 11-05-2018, 08:51 PM   #1
Question Inconsistant hot water amount
First time this happened: Plenty of hot water for a couple of showers. Two showers had only 2-3 minutes of hot water. I let the WH run until it shut downs between showers. Any thoughts?
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline   Reply With Quote
Old 11-05-2018, 08:57 PM   #2
Flybob's Avatar
Check outside shower to make sure it is off. Also check WH bypass valve to make sure it it correct position. The water pressure can also impact how long the HW lasts. Higher pressure means higher water flow and shorter hot water shower.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-05-2018, 10:55 PM   #3
A32Deuce's Avatar
If its propane and electric, use both at the same time. Recovery is much faster.
A32Deuce is offline   Reply With Quote
Old 11-06-2018, 08:42 PM   #4
I have a pressure regulator in place. By-pass valves have never been touched but I will check them. Thanks.
Old 11-06-2018, 11:00 PM   #5
Water heater make/model?
Tank or tankless?
Days Camped: '16=46 '17=30 '18=51 '19=27
Old 11-06-2018, 11:05 PM   #6
Scoundrel
HangDiver's Avatar
Outside shower knobs have to be turned off, not just the button on the shower head.
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 11-06-2018, 11:40 PM   #7
cavie's Avatar
My money is on the outside shower valve.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 11-07-2018, 03:15 PM   #8
Had same problem on my flipper wife shower was just warm my shower would be hot turns out one valve on water heater was turned wrong way
johnlochbuie is offline   Reply With Quote
Old 11-07-2018, 03:36 PM   #9
Take a look at this thread, it may solve your problem.
NO (OR LUKEWARM) HOT WATER -Please read first
Iwritecode is offline   Reply With Quote
Old 11-07-2018, 08:01 PM   #10
Thanks for the input. No outside shower. Standard six gallon suburban WH.
hot water, mount, water
