Old 01-24-2019, 07:43 PM   #1
Inop tankless water heater
Iím on the maiden voyage of my new 2019 Dynamax Isata 3. When we made it far enough south to dewinterize I discovered I couldnít get my on demand water heater to function. I turned on the switch outside at the unit and turned the rotary knob inside on. None of the LED lights have came on. What have I missed?
Derfsivad is offline   Reply With Quote
Old 01-25-2019, 07:48 AM   #2
What brand? In our River Stone we have another switch inside the control panel and not to be smug, is the gas on?
2017 River Stone Legacy 38mb
2001 Kenwoth T2000
2008 Smart on deck
dblr is offline   Reply With Quote
Old 01-25-2019, 03:39 PM   #3
Itís a Therma. Iím confident the gas is on. I canít locate any additional switches but I would be pleased if someone could direct me.
Old 01-25-2019, 03:57 PM   #4
Could a by-pass valve be turned so water is not going into the water heater? Just thinking out loud since you mentioned de-winterize.
2001 Kenwoth T2000
2008 Smart on deck
Old 01-25-2019, 05:27 PM   #5
Thanks, dblr!!
I found the switch on the control panel and found the bypass valves! We have hot water! Thanks again!
Old 01-26-2019, 07:47 AM   #6
Great glad things worked out for you.
2001 Kenwoth T2000
2008 Smart on deck
Old 01-26-2019, 04:36 PM   #7
Turn the inside control switch to OFF position for approx 5 seconds, then turn ON, should get the lite on knob to turn on,
Kenpet50 is offline   Reply With Quote
heater, tank, tankless, water, water heater
