Old 11-16-2012, 09:37 PM   #1
Oklahoma Proud
MillerTime's Avatar
? install of tornado tank rinser
If I install a tornado tank rinser, can or how do you do it with a inclosed underbelly?
I don't have the water and sewer cabinet area like some rvs just the outside mounts for water and sewer.
Old 11-17-2012, 12:33 AM   #2
Fulltime family RVer
A tornado tank rinser for my 2nd black tank is on my list of todos. I also have an enclosed underbelly. I assume I'll have to take a section down to get to the tank. While I'm at it, I plan on installing the Horst probe/sensors.
Old 11-18-2012, 07:03 AM   #3
Herk7769's Avatar
I think you will love both mods.
I do.
HAM CALLSIGN - KC3FFW
Old 11-18-2012, 08:15 PM   #4
BigTJohn's Avatar
Tornado rinsed is the best. Easy to install and easy to use. Horst proves are also great. Tornado will rinse probes clean (most of the time) so Horst probes are a good idea.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 11-18-2012, 08:32 PM   #5
Oklahoma Proud
MillerTime's Avatar
What I was wondering was, with inclosed underbelly-
1. Is it a total pain to use?
2. If leaving belly intact do you use a short piece of hose to move to a remote location?
3. How have you done it IF you have the enclosed underbelly.
I just hate dragging a hose through the trailer and want a quicker clean out when at a dump station. I already have the clear elbo w/flush, and a clear w/valve to back flush gray into black(also has flush valve) and for equilizing gray tanks.
Old 11-18-2012, 11:28 PM   #6
Herk7769's Avatar
Dropped one side of the underbelly today and installed a turbo rinser on my gray tank. I had to install it on the same face as the probes are installed since there was no room to work on any other side. I routed the included clear hose to the side of the dump mast valve so it would be easy to get to.
I sliced the belly coroplast along a wood stringer (that was secured by a metal strip) so I did not have to drop the entire thing.
Total time from starting to drop the panel to the last screw was about 2 hours.
Easy install. Hardest part was buying the 1 3/4 inch hole saw at Lowes.
Old 11-19-2012, 08:23 PM   #7
Oklahoma Proud
MillerTime's Avatar
Thanks!
