Old 12-22-2007, 03:54 PM   #1
Installed the water pressure regulator
I bought one of those fancy water pressure regulators and was just going to install it at the spigot each time but decided to put it in the camper permanent like. Here's some pics:
I put that stainless steel hose in there so I was protected inside the trailer. My supply hose to the spigot will not be protected, but if it bursts, it just makes mud.
Comments are welcome.
Tom
Here's where I got the regulator:
http://www.rvwaterfilterstore.com/Pr...m#PressureInfo
tomhole is offline   Reply With Quote
Old 12-22-2007, 10:08 PM   #2
What is the SS hose rated at?? Reason I ask I have been to several CG that had pressures of 100 and 160 psi. Out west high pressures are not uncommon.
I mount mine right before the inlet of the tt. My hoses are rated to 160 psi, yes they can be found in potable water hoses.
Nice set up if you are protected by the SS hose.
Paul B
2001 Excursion PSD
2000 CRV Honda
2006 829GRSS Flagstaff TT
2004 Twin 2000i Hondas'
Paul B is offline   Reply With Quote
