04-28-2018, 06:04 PM
installing a handicap handle in shower
I'm wanting to install a handicap handle in our shower for my wife. Has anyone done this? Where can I purchase one, how hard are they to install.
04-28-2018, 06:35 PM
You supply No Info on type of RV! Handicap rails require lots of support not found in many RV shower areas! Youroo!!
04-28-2018, 08:18 PM
My bad. We have a 2015 Rockwood Signature ultra lite 8289ws
04-28-2018, 08:38 PM
I've been thinking about the same thing and haven't come up with anything yet.
04-29-2018, 03:32 PM
Try a Handicap specialty house.
I found a portable one that uses suction cups on both ends. It's not made for full weight lifting but for steadying and providing some support to lift oneself up.
Make sure the surfaces are clean and will take the suction without an air leak.
Also take it off and reattach it occasionally.
04-29-2018, 04:18 PM
Those suction cup things work great in our tiled bath, but he walls in the camper are more like wallpaper on cardboard. BTW Harbor Freight has the best prices on the suction cup handles.
I'm thinking about making plywood reinforcements on both sides of the bathroom wall...that span the entire area and use them as a reinforcement for the grab bar.
Pics when I do the install.
04-29-2018, 04:36 PM
As mentioned, finding something to mount the rails to is going to be difficult. Might be better off with a freestanding type of support rails.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
04-29-2018, 05:46 PM
I've been thinking about a shower stool like this, but I haven't measured to see if it'll fit the person or the shower yet.
https://smile.amazon.com/Rotating-An...p+shower+chair
2015 Dynamax REV 24TB class C
04-29-2018, 05:59 PM
We have installed handicap handrails in our home bathroom, but our Aframe doesn't have bathroom facilities. You can purchase handrails at Home Depot, Lowe's, Amazon, etc. I would hesitate on suction cup ones just for the simple fact if they fail or come loose it could be disasterous.
To install the handrails, my husband having been in construction, used a 2x4 approximately 1' longer than the handrail. He mounted the 2x4 on all of the available studd locations. Then mounted the handicap handrail to the stud. So much easier and you don't have to match the handrail ends to a stud that may or may not be available. I don't know about the structure of your TT and available support points. Something to check out.
Hope that helps.
04-29-2018, 06:32 PM
This is the one for you!
Randy, if your shower stall has a smooth plastic liner, this is the one for you! It has a REALLY GOOD suction cup at each end. Just place it where you want it and lift the lever at each end.
We bought one to use at home and had to return it because our shower has the old-style 4-1/4" square tiles and there was no way to position the handle such that one end didn't span a seam and not seal. But even the one end held on really tight. We couldn't budge it. (That's why you need a seamless shower stall as all the plastic one are.)
Larry
04-29-2018, 06:35 PM
Originally Posted by Reverse_snowbird
I thought about using one of these, but afraid that it would punch holes in the floor of shower. (???)
04-29-2018, 07:23 PM
I bought a suction cup version at Bed, Bath and Beyond for one our bathrooms at home. Work great, only came off wall once in about two years. The walls must be smooth and clean.
As mentioned above, if installing on tile make sure the suction cups are entirely on the tile.
2017 Dynamax REV 24RB
2018 Ford F-150
04-29-2018, 07:42 PM
There was a vendor at FROG last year selling all kinds of HD Suction Cup things. I don't remember any being specifically for the shower.......most were outside (flags, flag poles, etc)........but I bet they'd work.
I don't remember their name............
FROG AR-0019-242
04-30-2018, 08:33 AM
I installed one of these in my shower @ home,,,
Great for helping keeping my balance,,,
Found them in stock @ Lowes,,, you can also check online !!!
04-30-2018, 11:56 PM
Harbor Freight sells these in 2 sizes for cheap! The do work very well. It's worth buying one there and trying it out.
OldBob
I may be old but I'm trying, very trying.
2015 RAM 1500 - EcoDiesel
Rockwood Ultra V 2715VS
05-01-2018, 09:03 AM
I don't know that I would trust Harbor Freight for a Grab handle in my shower ???
05-01-2018, 12:49 PM
I have 4 Harbor Freight Grab Handles in my home shower for my handicapped wife. I also keep one in the car for times we do a motel on the road. I check them before she uses them. No problems so far.
The more expensive ones have an indicator that shows red if the suction has let go - I prefer to just give them a good tug before they're used.
05-02-2018, 02:02 AM
This is the Harbor Freight Suction Grab Handle. It really DOES work well and for less than $7 you can't beat it!
https://www.harborfreight.com/bath-s...dle-96086.html
OldBob
05-02-2018, 09:14 AM
Lowes 12" Grab bar from Moen is $17 !!!
I think they also have a 9" for a little less !!!
05-02-2018, 09:59 AM
Screw-in?
I thought the Moen was a screw-in model. I don't think the plastic shower liner would hold that, and it would be hard to fit a 12" bar across 16" on-center studs.
Gotta go with a suction cup model.
Larry
