Old 04-28-2018, 06:04 PM   #1
installing a handicap handle in shower
I'm wanting to install a handicap handle in our shower for my wife. Has anyone done this? Where can I purchase one, how hard are they to install.
Randy M. is offline   Reply With Quote
Old 04-28-2018, 06:35 PM   #2
You supply No Info on type of RV! Handicap rails require lots of support not found in many RV shower areas! Youroo!!
Old 04-28-2018, 08:18 PM   #3
My bad. We have a 2015 Rockwood Signature ultra lite 8289ws
Old 04-28-2018, 08:38 PM   #4
I've been thinking about the same thing and haven't come up with anything yet.
jeffnick is offline   Reply With Quote
Old 04-29-2018, 03:32 PM   #5
Try a Handicap specialty house.
I found a portable one that uses suction cups on both ends. It's not made for full weight lifting but for steadying and providing some support to lift oneself up.
Make sure the surfaces are clean and will take the suction without an air leak.
Also take it off and reattach it occasionally.
Cold Lake Kid is offline   Reply With Quote
Old 04-29-2018, 04:18 PM   #6
Those suction cup things work great in our tiled bath, but he walls in the camper are more like wallpaper on cardboard. BTW Harbor Freight has the best prices on the suction cup handles.
I'm thinking about making plywood reinforcements on both sides of the bathroom wall...that span the entire area and use them as a reinforcement for the grab bar.
Pics when I do the install.
Old 04-29-2018, 04:36 PM   #7
Flybob's Avatar
As mentioned, finding something to mount the rails to is going to be difficult. Might be better off with a freestanding type of support rails.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-29-2018, 05:46 PM   #8
I've been thinking about a shower stool like this, but I haven't measured to see if it'll fit the person or the shower yet.
https://smile.amazon.com/Rotating-An...p+shower+chair
Happy Camping!
2015 Dynamax REV 24TB class C
2nd rig 2006 Toyota Tundra &
2010 Cikira 21RB 19' travel trailer
Reverse_snowbird is offline   Reply With Quote
Old 04-29-2018, 05:59 PM   #9
Around the Bend's Avatar
We have installed handicap handrails in our home bathroom, but our Aframe doesn't have bathroom facilities. You can purchase handrails at Home Depot, Lowe's, Amazon, etc. I would hesitate on suction cup ones just for the simple fact if they fail or come loose it could be disasterous.
To install the handrails, my husband having been in construction, used a 2x4 approximately 1' longer than the handrail. He mounted the 2x4 on all of the available studd locations. Then mounted the handicap handrail to the stud. So much easier and you don't have to match the handrail ends to a stud that may or may not be available. I don't know about the structure of your TT and available support points. Something to check out.
Hope that helps.
Around the Bend is offline   Reply With Quote
Old 04-29-2018, 06:32 PM   #10
This is the one for you!
Randy, if your shower stall has a smooth plastic liner, this is the one for you! It has a REALLY GOOD suction cup at each end. Just place it where you want it and lift the lever at each end.
We bought one to use at home and had to return it because our shower has the old-style 4-1/4" square tiles and there was no way to position the handle such that one end didn't span a seam and not seal. But even the one end held on really tight. We couldn't budge it. (That's why you need a seamless shower stall as all the plastic one are.)
Larry
Larry-NC is offline   Reply With Quote
show, shower
