Old 05-20-2015, 12:50 PM   #1
Installing Horst tank sensors
I want to install Horst sensors on my Grey Wolf travel trailer. The stock sensors are glued in with some sort of impervious material so drilling new holes seems to be the only answer. However, I can't get to the top two sensors without dropping the tank. The tanks appear to be held in with angle iron that is removable. What I wonder is: how far can I drop the tank without causing the connections on the top of the tank to come loose? I have the feeling the tanks were set in the frame before the body of the trailer was added and some of the connections could be very difficult to get to were they to come loose.
Thanks, Mike
mharrel is offline   Reply With Quote
Old 05-21-2015, 06:57 AM   #2
Herk7769's Avatar
Can you post a photo?
Maybe it is just RTV sealant?
HAM CALLSIGN - KC3FFW
Old 05-21-2015, 09:32 AM   #3
Hi Lou--We discussed this back in Nov. The pic is in the link below. I'm now to the point of dropping the tank, less risk I think, but I wonder how far I can drop it. Thanks
Replacing Tank Sensors
Old 05-21-2015, 09:48 AM   #4
I have the same type of sensor. They are glued or plastic welded in. If you want to put the horst sensors in i think you will need to drill new holes next to the existing sensors.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 05-21-2015, 12:26 PM   #5
Herk7769's Avatar
Ah, I thought the issue was familiar.
I don't have anything more to add than I already did.
Be careful dropping the tank, as the vent and inlet pipes may need to be severed and then coupled with a rubber sleeve union. I have neither dropped a tank nor seen one done. You may need professional advice.
Maybe a YouTube Video exists.
I found a repair the tank video, but the getting it out part was missing.
Old 05-21-2015, 03:51 PM   #6
Evereddie's Avatar
Is there any place on the tanks where you can install new probes. Maybe there is another spot that is in the clear for drilling?
Evereddie is offline   Reply With Quote
Old 05-23-2015, 08:39 AM   #7
You know, sometimes I have trouble thinking out of the box. I had just always planned to put the new sensors right next to the old ones. In reality, I can put them anywhere I want. I went to the other end of the tank and I can get an angle drill in there. Patch in some wiring and I'm done. Now, I haven't done it yet, but will as soon as it quits raining. Thanks for the suggestion.
Old 07-12-2015, 03:37 PM   #8
I finished installing the sensors--no problem. For the black water tank, I went to the other end of the tank and installed them there. I had to add jump wires but that was no problem. It also occurred to me that if there were no way to get at the tank, holes could be drilled through the I beam slightly larger than the 3/8 hole the sensor has to have. Then drill the hole in the tank through the hole in the I beam. Thanks to all who helped.
Old 07-12-2015, 04:31 PM   #9
Evereddie's Avatar
Have you used them long enough to tell an improvement?
Old 07-12-2015, 04:56 PM   #10
boatman
boatman's Avatar
mharrel if your talking about drilling a hole in the main camper frame I beam bad idea you should never drill a hole in your frame.
boatman is offline   Reply With Quote
tank
