Old 06-19-2016, 07:26 AM   #11
DouglasReid's Avatar
why pull tanks?
Im with those who just connect the RV plumbing with PVC (or ABS if that is what is used in your area). It is easier, faster, less expensive and has the added benefit of being easy to unhook if/when you decide to move or sell the camper.
All upsides and no downsides that I can see.
DouglasReid is offline   Reply With Quote
Old 06-19-2016, 08:01 AM   #12
Oklahoma Proud
MillerTime's Avatar
Here is our set up. It runs to a septic tank we share with another camper.
We leave our shower gray tank open when we are there. With 3 kids, we have to. Plus our septic tank system can't handle us dumping all 5 tanks at once.
We have a short piece of sewer hose that connects to our pvc.
Old 06-19-2016, 08:08 AM   #13
All looks good, but you must use a ton of chemicals in the tank.
The trap will take care of the sewer gas but what about the tanks gases
Jack L
Jack L is offline   Reply With Quote
Old 06-19-2016, 08:45 AM   #14
Wolverine 1945's Avatar
I guess I have to wonder what type of septic tank you have that won't handle dumping 5 tanks ???
Wolverine 1945 is offline   Reply With Quote
Old 06-19-2016, 09:57 AM   #15
Oklahoma Proud
MillerTime's Avatar
Most tanks are 1000 gallons. If i dump 200 + gallons it overloads the leach lines that are designed to handle a few dozen gallons an hour. If done consistently, the solids or the top scum will be forces into the leach lines and render them useless. They are only designed to handle liquid.
That's why septic tanks need to be pumped every few years, and why dumping large quantities into them in a short timeframe will ruin one.
I've lived with septic tanks my whole life, as well as having a heavy construction company that serviced and installed failed systems some times.
Old 06-19-2016, 10:57 AM   #16
Yes that all makes sense !!!
Maybe you could dump them over a # of days ???
Old 06-19-2016, 01:44 PM   #17
Oklahoma Proud
MillerTime's Avatar
Thats what we do. We leave the shower, gray tank open though, to help with not having as much water to dump at one time. Just while we are there though. All valves are closed when we are gone.
Old 06-19-2016, 01:50 PM   #18
Oklahoma Proud
MillerTime's Avatar
Jack L
You will have vents on all your tanks. Plus all the gray water connections have their own p-traps. The toilet is the only one without a p-trap. That's why its essential to leave water in the toilet bowl.
Also, we drop a tablet down each of the 2 black tanks after dumping the tank, so thats every weekend that we use it on 1 tank, and about once a month for the other. The gray tanks we don't use chemicals in unless we have a slight odor. Then we just add some pinesol and add some more water.
Old 06-19-2016, 04:42 PM   #19
hard hook up
I agree. use your PVC and fern coats( rubber coupling) to hook up. Don't get rid of your tanks.
jpbrough is offline   Reply With Quote
Old 06-19-2016, 06:03 PM   #20
Some one needs to tell my septic tank that !
It is now 30 years old, and never has been pumped
jack L
