Old 06-18-2016, 05:57 AM   #1
Installing into permanent sewage question
We will be putting a new Forest river Wildwood on our permanent RV site and sometime I would like to hard plumb the sewage system.
If any one has done this, how hard is it to remove the black and gray tank and do this?
Can you walk me through the process
jack L
Jack L is offline   Reply With Quote
Old 06-18-2016, 06:04 AM   #2
Herk7769's Avatar
I recommend you contact a qualified plumber to do this.
As I understand it, once you do things like removing wheels and axles, removing the A-Frame, and permanent connections to the site, it is no longer an RV but a manufactured home. Permits are normally required and it then becomes "Real Estate".
HAM CALLSIGN - KC3FFW
Old 06-18-2016, 07:37 AM   #3
kc8lvy's Avatar
Why remove your tanks? I have been full timing now for 2 years and I just go out once a week and dump the black tank and every 3 days on the grey tanks until I hooked mine up to PVC and put a trap in it now I leave my greys open until a day or 2 before I dump my black tank. I like to flush out the pipe good. if you want to hook up PVC instead of the slinky you can do it easily.
I just got a clear straight Flush King and ground off the nubs on the one side and got a 3 inch rubber coupling to connect that to the PVC pipe I made my own trap so I don't get any sewer gas and got a screw in connector for the park connection and I also put in a 3 inch rubber connector near the elbow in case I need to remove it. I went extreme with my trap I probably could have used 4 45s instead of 4 90s. Now its time to clean up my mess of hoses and make a nicer support for the sewer pipe.
ID:	111447   Click image for larger version
ID:	111448   Click image for larger version
2004 Dodge Ram 2500HD Cummins
2017 Keystone Montana 3820 FK
2009 Harley Davidson Ultra Glide
kc8lvy is offline   Reply With Quote
Old 06-18-2016, 07:41 AM   #4
Head Rambler
Physically doing the work isn't too hard.
You'll have to access the inlet connections on the tanks and cut those loose. Once you've done that it's just a matter of finding connectors for the piping and running the piping to the sewer system.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 06-18-2016, 08:08 AM   #5
kc8lvy's Avatar
You fill have to install a regular house flush toilet if you remove your Black tank.
Old 06-18-2016, 09:03 AM   #6
Originally Posted by kc8lvy View Post
You will have to install a regular house flush toilet if you remove your Black tank.
kc8lvy is right, the larger volume of water is necessary to move solids down the pipe, .... the regular rv toilet doesn't have enough water with each flush to accomplish that, because it doesn't need to, it's only going to drop the contents into the tank below,..... sure sounds like you're putting a lot of work and cost on yourself that is certainly avoidable
kc8lvy's photos show the most common way that I've seen used on a permanent setup trailer,..... plus, its still a trailer, if your plans ever change, you're selling a regular trailer not a modified unit that would only be useful to a much smaller group of buyers,..... that's just my 2cents worth, best of luck on whatever you decide to do...........
fella10 is online now   Reply With Quote
Old 06-18-2016, 11:43 AM   #7
arpipeliner's Avatar
I use this set up when I hard pipe for winter.
arpipeliner is offline   Reply With Quote
Old 06-18-2016, 11:04 PM   #8
poofam's Avatar
We full time
We full time in a 300 + campground and most the people run a 4" pipe I put a T fitting on mine so I can see what is coming out. I haven't seen anyone have a P trap on there's, I have 3 tanks in a Landmark, black, shower (gray), kitchen sink (gray). I leave the black and kitchen closed with shower open all the time with no problem. I also took a garbage can and cut the bottom out and put all my water connections in there with a trouble light for winter so lines don't freeze. Will try and post pics
poofam is offline   Reply With Quote
Old 06-18-2016, 11:16 PM   #9
poofam's Avatar
Pics I hopeClick image for larger version
Name:	ImageUploadedByForest River Forums1466309625.218621.jpg
ID:	111545Click image for larger version
Name:	ImageUploadedByForest River Forums1466309662.198854.jpg
ID:	111546Click image for larger version
Name:	ImageUploadedByForest River Forums1466309766.000919.jpg
Old 06-19-2016, 07:23 AM   #10
Wolverine 1945's Avatar
I am very surprised that waste could make it thru that P trap ???
Wolverine 1945 is offline   Reply With Quote
