Old 11-09-2010, 12:40 PM   #21
Herk7769's Avatar
Ok, lets take a poll. Who removes their water pump to save 6 dollars in anti-freeze....
Anyone?
Come on, somebody?
HAM CALLSIGN - KC3FFW
Old 11-09-2010, 03:55 PM   #22
Anyone?
Come on, somebody?
Kirk, KN1B
2013 Cardinal 3800FL
2009 GMC 3500HD CC LB SRW
kbrown1075 is offline   Reply With Quote
Old 11-10-2010, 11:06 AM   #23
THE NEW GUY
everybody has different opinions, thats whats great about this site.
DAVE FIORE
2011 ROCKWOOD 2608SS
2500 AVALANCHE 8.1 3.73
rvgolfer is offline   Reply With Quote
Old 11-10-2010, 01:10 PM   #24
acadianbob's Avatar
Who REPLACES their water pump every year because of inadequate winterization?
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 11-10-2010, 01:28 PM   #25
Herk7769's Avatar
I did a web crawl on the forum and could not find one example. This could be because anyone who uses anti-freeze would never have the issue or those that blow out their lines run the pump dry when they drain their fresh tank for the winter or they went "barefoot" and were lucky (or very quiet about it if the pump check valve failed due to ice.).
In any case I am thinking the "at risk" pool is very small.
Old 11-10-2010, 01:46 PM   #26
Grape Escape
Lets close this and get on with life
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 11-10-2010, 02:08 PM   #27
Herk7769's Avatar
OK by me
I did learn a lot about the water system and where the check valves were located. I even bought a pre-made water blow out fitting to hook up to the city water connection to switch from RV antifreeze to air. MUCH cheaper way to winterize (all things being equal).
Then Acadianbob mentioned the water pump and I remembered the fresh water side check valve is IN the pump. Without blowing the air through the pump, it is possible (however unlikely) for the water trapped in there to freeze and damage it. Now the pump is just a hundred bucks and easy to change, but why take the chance?
Old 11-10-2010, 04:10 PM   #28
Grape Escape
Maybe it would not be such a bad idea to damage the cheap pump .
It would be an excuse to buy a new quieter more powerful one
Old 11-11-2010, 06:35 AM   #29
Dodge Guy's Avatar
Instead of these maybe`s, and probably`s and hopefully`s why not just use the RV antifreeze that is non-toxic and not worry?!
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 11-11-2010, 04:01 PM   #30
THE NEW GUY
its my fault bad idea. I will bow to the antifreeze gods
DAVE FIORE
antifreeze
