07-04-2016, 03:35 PM
Is it possible I damaged my heating element?
Hi all. Just returned from camping for the weekend. Realized about an hour after I got home I forgot to flip off the electric switch for my hot water heater about an hour after I plugged it in at home. As soon as I realized it, I ran out and turned off the switch, opened up the relief valve and drained out about a SOLO cup full of very hot water. Did I get lucky having that bit of water in there or could I have damaged it? Maybe I won't find out until our next trip. But what I drained was very warm.
Thanks!
07-04-2016, 03:45 PM
Did you drain all of the 6+ gallons of water out of the water heater - through the drain plug/anode at the bottom of the heater? I doubt if you did. I'd say your tank was still full so there's no likelihood of damage. The water you got out of the pressure relief valve is a tiny percentage of water in the heater tank. What kind of heater do you have? Model number?
07-04-2016, 03:47 PM
My understanding I if you had water in it you would be safe. If you opened the pressure relief and got a cup of water then there is more water in the tank. Pull the diode (if you have one) and that would tell you how much water was in the tank. Hopefully more knowledgeable people will pipe in soon.
2017 Keystone Cougar 28RDB
07-04-2016, 03:51 PM
Originally Posted by Buck1032
.... Pull the diode (if you have one) and that would tell you how much water was in the tank....
Not diode... but anode............ but DON'T PULL IT IF THE WATER'S HOT. It will put you in the ER if it's still under pressure.
EDIT: Never pull an anode rod (or drain plug if an Atwood heater) until the water is cool and the pressure is off.
07-04-2016, 04:00 PM
It is a Suburban. I did not drain the water through the bottom plug, but before I left the campground I opened all my faucets and drained the freshwater tank. This would not have drained the water in the system (opening all faucets)? Do I need to remove the bottom plug from the heater after each trip to drain the water heater?
07-04-2016, 04:06 PM
You are correct anode. Sorry if I confused anyone. I defer to Mr. Dan.
07-04-2016, 04:08 PM
I almost never drain ours, and as said above, unless you drained it through the bottom drain (Anode Rod) you didn't drain the water out of the tank and therefore you didn't hurt the element.
Gotta go campin!
07-04-2016, 04:11 PM
You're good to go for next trip, no damage done.....
Fonzie
07-04-2016, 04:15 PM
I drain my water heater once per year - when I winterize. We use ours often enough that I don't feel the need to drain it until winterization. Others drain after each trip... not necessary IMHO.
07-04-2016, 04:41 PM
Cyber Phrenologist
I only drain mine when putting it away for the winter.
KU4OJ
2008 (or is it 2009?) Rockwood 8280SS - 2022 F-250 7.3L
07-04-2016, 04:46 PM
If water came out of the pressure relief valve you had water in the tank and should be OK. The valve is near the top of the tank. I put a label on the power cord to remind me to check the WH switch before plugging in
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
07-05-2016, 11:59 AM
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
the only way your heater element will fry is if it's turned on and exposed to air. And it only take a minute or so to fry it. If it's in water, you've done no harm.
07-05-2016, 12:06 PM
Yes, if you got water coming out from your pressure relief valve at the TOP of your water tank, then it should be full of water still, and the electric heating element at the BOTTOM of the tank is OK since it was still immersed in water.
2011 Flagstaff 831 RLBSS
In my case I can do a full HW Tank by opening facets and pull the low point drain plugs. This will suck the water out while driving down the road.
B and B
07-05-2016, 12:16 PM
I bet that Motorcyclist love to travel on a Dry road you have just Watered Down! Youroo!!
07-05-2016, 04:06 PM
2007 WildCat 32QBBS
And in New Jersey can get you a summons.
