Old 01-29-2018, 11:39 AM   #1
Is this even possible?
We were out camping last week and on Saturday night (the 4th night of our trip) 2 streams of water started trickling from the bottom of the 5ver. I immediately turned off the shore water and waited until the water stopped trickling and turned on the electric pump and used the onboard water tank. It came up to pressure and shut off, no leaks so, we just used that the rest of our trip. The campground had a notice saying that the pressure exceeded 60 psi but, I didn't think to put a regulator inline. Today I went out and removed the panel hooked it up to our house supply (a well) and checked for leaks it is not leaking. It has been hooked up for about an hour and no leaks. Is it possible that the Campground water pressure spiked causing the leak but now at the lower pressure it is ok?
Just remembered something. We were camping with a large group of friends (about 15 RVs) and two other people told me they had leaks but not as bad as mine.
Thanks in Advance
Rick
RickV is offline   Reply With Quote
Old 01-29-2018, 11:44 AM   #2
Scoundrel
HangDiver's Avatar
City water filling Fresh Water Tank!
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 01-29-2018, 11:52 AM   #3
rracer5's Avatar
Originally Posted by RickV View Post
We were out camping last week and on Saturday night (the 4th night of our trip) 2 streams of water started trickling from the bottom of the 5ver. I immediately turned off the shore water and waited until the water stopped trickling and turned on the electric pump and used the onboard water tank. It came up to pressure and shut off, no leaks so, we just used that the rest of our trip. The campground had a notice saying that the pressure exceeded 60 psi but, I didn't think to put a regulator inline. Today I went out and removed the panel hooked it up to our house supply (a well) and checked for leaks it is not leaking. It has been hooked up for about an and no leaks. Is it possible that the Campground water pressure spiked causing the leak but now at the lower pressure it is ok?
Thanks in Advance
Rick
I would tend to think you are correct. Although the plumbing lines are rated at very high pressure, the fittings (plastic) and clamps are not. That and the temps. if low, may have shrunk the fittings enough to allow leakage under high pressure.
If you are able to find the source of the leak, sometimes a little extra tightening (tweek) of the fitting or maybe an extra wrap of teflon tape will cure the problem.
Or, if YOU can locate the source and show it to the dealer, make them fix it. Otherwise, they will just do what you did and if their water pressure is low it won't show & they'll just say "nothings wrong, couldn't find it".
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 01-29-2018, 11:58 AM   #4
No it wasn't coming from the fresh water tank. I had to fill the fresh water tank it was only about 1/4 full.
2014 Crusader 325res Touring Edition
2003 Silverado Duramax 6.6 Dually Longbed 2wd Crew Cab
Old 01-29-2018, 12:02 PM   #5
5ver is 4 years old ain't no make dealer fix it.
I will leave it hooked up and keep checking on it as our well pressure fluctuates.
Old 01-29-2018, 12:08 PM   #6
rracer5's Avatar
Ahh, didn't know how old it was cause you said 4th night out.
Like I was saying, age & temps. can cause leaks over time. I've had a few that have required extra tape or a little tweek.
2014 Sanibel 3250
Old 01-29-2018, 12:49 PM   #7
Yeah if it was the 4th night out it would definitely be at the dealer. 😎🍺
Old 01-29-2018, 01:16 PM   #8
Thanks in Advance
Rick
Do you have any idea of where this was coming from?
Is your underbelly enclosed?
Do you have a wet bay?
If not, any possibility it was leaking at the city water hose connection and running down the side and then dripping under the camper?
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 01-29-2018, 01:43 PM   #9
Had a very slow leak only when hooked up to city water. Dealer couldn't find it, told me there was no leak. After much digging around I found a pex clamp that wasn't crimped.
Go UK is offline   Reply With Quote
Old 01-29-2018, 01:58 PM   #10
Flybob's Avatar
Very possible it was the campground. Campgrounds do not use the same robust water systems as a municipal system. In order to insure that the people at the ends of the system have sufficient pressure, they need to raise the pressure at the head end. Also some use water towers where the pressure when full can be significantly higher than the pressure when partially full. It is very possible you incurred at high pressure which caused a fitting to leak. You should always use a good regulator that actually adjusts the pressure and not restricts the flow to simulate reduced pressure.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
