12-08-2016, 09:31 AM
#21
This is very helpful for us as well. Thanks.
Charleston SC
Rockwood Ultralite 2304DS
June 2016
30+ nights
12-08-2016, 10:12 AM
#22
...another buttered popcorn thread.....
12-08-2016, 10:37 AM
#23
(Dry Huunday)
'tis the season!!!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
12-08-2016, 11:49 AM
#24
Mine looked like that and I replaced it. Worn thin around the threads (like yours), I was afraid it would break off. I bought a replacement and a spare from Amazon. Easiest way for us country boys to shop, got here in two days.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
12-08-2016, 12:00 PM
#25
Originally Posted by Toolman Gary
I own an Ace Hardware and we carry them in our store so you can check any Ace.We are usually a little easier to get around in rather than the big box stores and we help the customer. Thanks,Gary
What?...................A Shameless plug for Ace Hardware.
Which I can not pass up and tend to go to often, especially if it's in the middle of an old business district somewhere and looks like it has been a hardware store for about 150 years.
Magnesium is the best, but if you know you have high iron content in the water use the aluminum, you'll need to replace it more often. The ones made of popcorn do not last long at all.
12-08-2016, 12:09 PM
#26
Left Coast
But you're not throwing away anything........for awhile...
12-08-2016, 05:10 PM
#27
One quick question, do all RV water heaters have anode rod? I don't recall mine having one on a 2012 model.
12-08-2016, 05:30 PM
#28
Left Coast
No...only Suburban
12-08-2016, 07:50 PM
#29
Looked at mine this fall and it is 99.9999% "new" condition........I do not think that is normal after 9 months of camping---5 of those were months were full time...J
12-08-2016, 07:52 PM
#30
Left Coast
I just took one out, this is a2010, and looks like new.....spent most of it's life in soft water.....
12-08-2016, 08:07 PM
#31
What exactly causes the corrosion of the bar? I know on a boat it is electrolysis caused by current in the water but I wouldn't think that was the case with a trailer. Is it just the chemicals in the water? I was surprised how much was consumed in one season.
Andersen hitch
12-08-2016, 08:10 PM
#32
Left Coast
I'd say the chemicals
12-09-2016, 06:03 PM
#33
Very likely the threads were effectively insulated by excess sealant. Next installation ,use a meter to verify a circuit between plug and frame.
12-09-2016, 07:00 PM
#34
Actually it's caused by dissimilar metals connected by electrolyte will cause current flow. In this case the magnesium will sacrifice flakes to the iron. The water (with impurities) is the electrolyte, connects the rod to the iron tank. Purpose being to coat exposed iron with tiny flakes. Sacrificially
12-09-2016, 07:33 PM
#35
See here:
Hot water heater anodes and rust protection
2011 Traverse LT, 3.6L, FWD
12-10-2016, 07:36 PM
#36
Too old to be too smart
Originally Posted by bob caldwell
No...only Suburban
Can an Atwood water heater be fitted with an anode rod?
Would there be any reason to do so?
Why would that sacrificial rod only be necessary in the Suburban models?
Thanks for any insight,
Pop
Terry 250RKS, perfect for the two of us and the pups.
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
12-10-2016, 07:37 PM
#37
Left Coast
Type of material the tank is made of
12-10-2016, 08:33 PM
#38
Pop
No need. An Atwood has an aluminum tank, and won't rust. This is an excerpt from another website:
The reason an Anode Rod is required by a Suburban Water Heater is because the tank of the Suburban Water Heater uses glass enamel over a steel tank. If the enamel cracks for any reason it will expose the steel to the water and the steel will start to corrode even from a pinhole in the enamel. The rod attracts the corrosive elements in the water that could corrode the water heater tank and the rod itself gets corroded.
The Anode Rod is part of the Suburban Water Heater's drain plug. It should be checked at least once a year .
So why doesn't the Atwood need an Anode Rod? The water tank on the Atwood Water Heater is made of aluminum which does not have the same corrosive properties as steel
2011 Flagstaff 831 RLBSS
12-10-2016, 10:43 PM
#39
I thought Atwood used a ceramic tank?
12-10-2016, 11:33 PM
#40
Here it is straight from the manufacturer (Atwood)
http://www.askforatwood.com/images/W...ceTri-Fold.pdf
and a zoomed in screenshot of their brochure warning explaining the tanks are aluminum and not to use anode rods.:
