12-07-2016, 12:30 PM
Is this hot water heater anode condition considered normal?
I just pulled the anode from my Suburban hot water heater. See attached pic.
Is this condition considered normal?
If I wanted to get a spare, does anyone know the part number? Is this something available at Home Depot or do I need to go to CW?
As always, thanks for the help!
Seakayaker
Charleston, SC
2016 Silverado 1500 LTZ
2016 Wildwood 27RKSS
12-07-2016, 12:39 PM
Looks pretty normal. You have a good bit of use left in that one.
232767 Water Heater Anode Rod is the Suburban part number.
Camco makes one. It's part number is 11563.
The camco unit is usually a little cheaper.
Gotta go campin!
12-07-2016, 12:44 PM
That is normal and can be reused as there is still life left on the rod.
It is sacrificial, so as it does its job, it gets eaten away.
I've never seen any at HD or Lowe's but have seen them at Walmart.
Usually right around $10 anywhere on the 'net.
The Suburban number is 232767.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=64
12-07-2016, 12:45 PM
Perfect. Thanks all around.
I'll go ahead and pick up a spare.
Charleston, SC
12-07-2016, 12:57 PM
Oh yeah, you are good to go for awhile with that anode. Here is a chart that Suburban has on their site, and we have in a few places here on FRF that shows the stage at which you should "probably" replace it at.....but you can do sooner if feel the need to.
2011 Flagstaff 831 RLBSS
12-07-2016, 01:04 PM
Amazon has therm as well...for armchair shoppers.
12-07-2016, 01:29 PM
Yes, the anode is doing its job, sacrificing itself so your water tank is not corroded!
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
12-07-2016, 01:46 PM
Anode rod
I own an Ace Hardware and we carry them in our store so you can check any Ace.We are usually a little easier to get around in rather than the big box stores and we help the customer. Thanks,Gary
12-07-2016, 01:52 PM
It's doing what it is supposed to. Walmart has the CAMCO #11563 for the Suburban heater (3/4" NPT), priced at $9.01.
12-07-2016, 03:31 PM
Magnesium is best!
I only use oem Suburban Part # 232767.
Not the Camco! The Camco is Aluminium. (doesn't wear out as fast BUT the Magnesium will protect your steel tank from corrosion much better. Only a few dollars more and well worth it.
I purchase mine from Amazon.com for around $12. each.
Purchase 2 and keep a spare on hand. I change mine out once a year (last about 18 months with heavy usage) You still have some life in yours.
Don't go the cheap rout as a new 6 gallon WH is around $00. tax included (that's not installed just the heater.
2016 Rockwood 2109S
2014 RAM 3500 - Cummins
165 Watts of Rooftop Solar
12-07-2016, 03:32 PM
$400.00 New WH
That's about $400.
2016 Rockwood 2109S
12-07-2016, 04:35 PM
Nice plug, Gary Where you at?
2014 Prime Time Sanibel 3250
12-07-2016, 08:24 PM
2003 Georgetown 325
The answer to the question is 'yup".
12-07-2016, 08:31 PM
Location: Chicago, Rochester now GA/SC at Lake Hartwell
I dunno...should I replace this one? (sarc)
It's a 2014
2019 Sandpiper 379FLOK, F350 Lariat 6.7 DRW, KN4YBP APRS, NRA Benefactors.
12-07-2016, 09:06 PM
It's a 2014
Boy, talk about getting your monies worth.
2012 Rockwood Windjammer 3008 W
2020 Tundra Dbl Cab 4X4 SR5
12-07-2016, 09:10 PM
When I pull mine when winterizing... I just toss it! For $12, good insurance and piece of mind. I know it's good for the new camping season!
2016 Vibe 268RKS
2015 Chev 2500HD
12-07-2016, 09:52 PM
RetiredRVer
Please throw some dollars my way! If you're replacing the rod every year, you're wasting your money. IMHO!
Joe & Sandy
Mentor, Ohio
2017 Ram Laramie Longhorn Crew Cab 4X4 Cummins Diesel
2017 Coachman Chaparral 336TSIK Fifth Wheel
2018 AT 18 Alaska group
12-07-2016, 10:09 PM
My rods are about half toast at this point!
2016 Vibe 268RKS
2015 Chev 2500HD
I checked mine when the trailer was new and I had just flushed the antifreeze out of it for the first time and it looked pretty used. I cleaned all of the gunk out of the WH and put it back in. Checking it at the end of the season again, it looked pretty much the same which got me to wondering if the antifreeze had done anything to it? (yes there was antifreeze in the heater, though not a lot) Next year, i am putting a new rod in and will check and see how much it is sacrificed. Since I use only air to blow out the lines and all tanks are emptied, the WH doesn't get any antifreeze, so I'll know if that had something to do with it or no.
12-07-2016, 10:10 PM
More info on Al vs Mg, FYI:
Aluminum or Magnesium anode on a new water heater?
2011 Traverse LT, 3.6L, FWD
