Old 05-19-2016, 03:36 PM   #11
BandJCarm's Avatar
Originally Posted by Mr. Dan View Post
So you don't have a water heater TANK... but you do have a water heater, do you not?
Yes, sorry. Didn't mean to imply that.
Yes, have a tankless water heater. So a pipe to fill up a tank isn't needed. BUT, the tankless heater has to have a supply, and the blue line with valve has to be it. The blue line without valve is apparently where the intake from outside cold water is.
The red pipe with valve is where water comes out from water heater 'hot', and then goes to camper feeds via the red line without valve.
I did not mean to be obtuse, but I honestly couldn't figure this out originally. I probably shouldn't have posted this until I thought it out some more.
I appreciate the help.
(I think if the two blue pipes were bent into one pipe, and the two red pipes were bent into one pipe........it'd look like everyone else's. And I think someone above actually said that and I was too dumb to get it at that time)
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 05-20-2016, 11:23 AM   #12
mike.t's Avatar
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 05-20-2016, 09:27 PM   #13
Now you've got it! Even with a tankless HWH, you still need to isolate the goes in and goes out and bypass it so you can winterize without putting antifreeze into the tankless heater. So the valving is the same irrespective of a tank heater or tankless heater.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
