Old 11-11-2015, 09:28 PM   #21
Beware of the back pressure valve under sink. The first time I use the black water flush, valve closed blew this valve and flooded the inside of the trailer. Actually there was a few bugs caught in the valve so it would not close.
AbdRahim is offline   Reply With Quote
Old 11-11-2015, 10:17 PM   #22
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
My valve was leaking from day one,,,,,,I replaced it with a better one that doesn't leak now.
Grampa Jim is offline   Reply With Quote
Old 11-11-2015, 10:49 PM   #23
SKnight's Avatar
Like many said, I put roughly four gallons in, three full toilets worth of water and on the fourth I add my chemical. That way I fill up the pipe with water, my chemicals go into the tank and I'm pretty sure there's a layer of water on the tank to help with solids that might be resting there.
Old 11-12-2015, 08:48 AM   #24
There's nothing wrong with putting lots of water in there. Like I said also,,,,,lots of water is the black tank's best friend.
Old 11-12-2015, 08:55 AM   #25
Flybob's Avatar
If you plan on leaving any water in either the black or gray tanks in an area that freezes, be sure you have added lots of antifreeze. Any water remaining will fill the drain pipes ( to the dump valves) and freeze and crack them.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-12-2015, 08:59 AM   #26
That's true, Flybob,,,,,but we have tank heaters that prevent that unless we get into really really cold climates....which we don't frequent anyways.
Old 11-20-2015, 07:02 PM   #27
One capful of Calogon water softner and one half cup of power laundry detergent and 2 to 3 gallons of water into an empty black tank.
whj469 is offline   Reply With Quote
Old 11-21-2015, 07:10 AM   #28
Wolverine 1945's Avatar
I have been using a Cup full of Liquid Detergent + Calgon !!!
Wolverine 1945 is offline   Reply With Quote
water
