Old 12-11-2015, 09:29 PM   #11
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
Your water heater won't boil out if you leave it on. I always use mine in the electric mode to save propane.
Grampa Jim is offline   Reply With Quote
Old 12-12-2015, 09:11 AM   #12
Whatever
PeterThePlumber's Avatar
Originally Posted by BooBoo23 View Post
If you are in freezing weather you need to disconnect the hose and drain it or it will expand and possibly burst. If you leave it connected in freezing weather the alternative is to heat trace the hose. As far as turning the supply off when you are away that is a good idea any time.
+1 on this! You say the shut off is below ground, so I'm guessing your in cold climate area. Maybe invest in some sort of heat tape/hose jacket combo it you want to stay hooked up. Or fill the onboard tanks; run off those; and disconnect the hose during cold weather.
I am only responsible for what I say, not what you may hear.
PeterThePlumber is offline   Reply With Quote
Old 12-12-2015, 09:24 AM   #13
Tom48's Avatar
Where ever the faucet fitting that you hook your hose to, be sure that your shut off comes first, your pressure regulator comes second and then your hose. There is no good reason to leave the higher pressure on that hose in hot or cold weather
When camping I ride my bicycle through the park and on a hot day you can see the hoses swell from the pressure when they put their regulator up at the trailer end of the hose. One fine spring day at Oceano Campground, Pismo Beach, CA I watched one burst with the camper sitting right in front of it, not realizing it was even a problem until it started spraying his camp.
And NEVER, NEVER leave the water pump on or the city line pressure on to your RV when you are away. A ruptured line, and separated fitting or even a bad dripping leak can RUIN the whole RV if you are not there to stop the problem when it starts. Same with the fire hazard of the water heater, no matter how slight the risk. Turn it off when you are not using it and for sure when you are not there.
Tom48 is offline   Reply With Quote
