Old 03-31-2018, 10:51 AM   #1
Kinked Water Hose
Hi everyone, Another newbie here. I just bought a Forest River Vibe (258RKS) and i have been going thru it to familiarize myself for the upcoming spring. During the inspection of the hot water tank and how the valve system operated I noticed a kink in the water line.
I am looking to remove it and cut a section out of it, or replace it, but I am not familiar with the method to remove the "clamp" that they have used.
i have tried a screwdriver that would fit in the slot but it will not open.
the first pic shows the kink. The second pic shows a better view of the clamp on the white hose that is used on all the fittings.
Really appreciate some insight to resolve this.
Tom
ID:	166694   Click image for larger version
Bigtee4 is offline   Reply With Quote
Old 03-31-2018, 11:22 AM   #2
Canadian Member
They PEX clamps. Search YouTube for "remove pex clamps" and pick the method you're comfortable with.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
itat is online now   Reply With Quote
Old 03-31-2018, 03:49 PM   #3
Take a pair of wire cutters and cut the raised piece of then clamp will come off. Shorten house and use a hose clamp to reattach. Check for leaks. That looks like a PEX fitting and is not sized for vinyl hose so it may leak.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
Old 03-31-2018, 03:54 PM   #4
those clamps use a special tool and special clamp. Cut it and replace with a regular old hose clamp
Kimber45 is offline   Reply With Quote
Old 03-31-2018, 04:31 PM   #5
Thurman's Avatar
Yep what #3 and #4 said, the hose is crimped because it was too long. Cut the clamp off with something like heavy duty wire cutters, shorten the hose and use an auto type hose clamp
Thurman is offline   Reply With Quote
Old 04-02-2018, 11:52 AM   #6
larry2c's Avatar
Just FYI, PEX tubing kinks fairly easily. They make "corner supports" for the PEX tubing that will prevent the kinks - you may want to get one (or a couple) to ensure there are no future kinks.
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Two shedding mutts
larry2c is offline   Reply With Quote
Old 04-02-2018, 12:01 PM   #7
Flybob's Avatar
Simplest solution might be to just cut out the kinked section of the hose to get the proper length then join the two hose pieces with a barbed hose coupling and hose clamps.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-02-2018, 12:12 PM   #8
You've received some good advice and I'll try to add a little more.
Since the hose that is kinked is braided, you CAN cut off the existing clamp (a PEX band clamp) and use an automotive type worm clamp.
Should you ever need to make modifications to the PEX tubing (the red and blue stuff) you WILL need to use a PEX clamp. They are designed especially for PEX tubing and you do need a special installation tool. (they make several styles) Using worm clamps on PEX tubing will fail.
The reason the factory uses PEX clamps on braided hose is simply for speed. They have the clamps and the tools and since they are clamping PEX, they also use them for braided hose too.
Days Camped: '16=46 '17=30 '18=51 '19=53
water
