Old 05-02-2014, 08:13 PM   #1
cnack72's Avatar
Kitchen faucet
I have a 2013 FR Surveyor sport 220. I de-winterized and have like foam continuously builds up in kichen sink.. Any tips would be great!!
cnack72 is offline   Reply With Quote
Old 05-02-2014, 08:32 PM   #2
B and B's Avatar
Hello, need to remove the aerator then flush the system more. Have you added bleach to the FW tank and sanitize the whole system. Also there could be air trapped in the HW tank, pull hi temp valve on the heater itself to remove water. I had to flush my water system in the trailer twice this year to get rid of antifreeze. Remember if you have a washer connection that needs to be de-winterized as well.
Brian
B and B
Old 05-02-2014, 09:00 PM   #3
cnack72's Avatar
How much bleach do you recomend i have 36 gal FW tank?
Old 05-02-2014, 10:39 PM   #4
B and B's Avatar
1cup mixed in a bucket of water to the FW tank. Then added about 1/3 of a tank of water. Flush, let sit overnight and repeat.
Brian
B and B
Old 05-03-2014, 07:39 AM   #5
MtnGuy's Avatar
1/4 cup of bleach for every 15 gals of water.
If your stated water capacity is 36 gals, that usually means you have a 30 gal. fressh water tank and 6 gal. water heater. If that is the case, 1/2 cup of bleach mixed in a gallon milk jug poured into a partially filled tank, then continue to fill the tank. If you choose to sanitize the water heater, then the concentration would be correct pumping from the fresh water tank.
faucet
