Old 04-03-2016, 07:08 AM   #11
nomad297's Avatar
The hot and cold hoses are sealed with an o-ring and not by threads up inside of the valve body. If you can spin the hoses clockwise, it will reseat the o-rings. If you are able to break it down to the inside of the valve body, you will see what I mean.
Bruce
Old 04-03-2016, 08:07 AM   #12
bulldog4949's Avatar
I was able to unscrew and rescrew back into the body. But it kept leaking.
2015 GMC 2500HD Duramax Denali
2015 XLR 300X12HP
2013 Polaris RZR 900 XP
bulldog4949 is offline   Reply With Quote
Old 04-03-2016, 11:45 AM   #13
Dahagen
Welcome to RV living. I replaced my kitchen faucet with a metal one from Lowes, took the old faucet and receipt into the dealership and they wrote a check for the faucet. My motorhome was less than one year old.
dahagen is offline   Reply With Quote
Old 04-03-2016, 02:04 PM   #14
That faucet is not cheap to replace. May be a cracked solder joint at the valve inside the faucet. If so probably not repairable. You could hook up to water supply now you have it out and maybe see more.
Harkerr is offline   Reply With Quote
Old 04-03-2016, 06:33 PM   #15
I have had to replace the kitchen faucet in ever RV I have ever owned. Plastic faucets do not hold up.
Also, check the water lines and make sure they are not stressed. I have had to re-run or relieve the stress on the lines where they were forced to go in a hole and it stresed the connection. If they are stressed, the connection will leak regardless of how tight it is. I have done all this in both Keystone and Forest River RVs - kitchen and bath faucets. Just expect it.
johnruff is offline   Reply With Quote
Old 04-03-2016, 11:03 PM   #16
Belin's Avatar
Kitchen faucet leaking
I had the same thing. The dealer fixed it because it was not a year old also.
It's a simple fix they told me what to do if it happens again. Mine happened they said because of my sink being on the slide out the sink hose drags every time the slide is opened and the plastic gasket came loose. There is a door frame under the sink that comes off so you can get to the hoses.
Belin is offline   Reply With Quote
Old 04-04-2016, 03:06 PM   #17
Thanks guys. I am certain it is coming from the copper solder joint from the spray nozzle and/or the brass valve body. It is not the water connections to the faucet. It up inside the faucet itself cause it's leaking down the hoses from above.
I unscrewed both and tried to reseat but no go. I called my dealer and am awaiting the service manager call back.
2015 XLR 300X12HP
Old 04-04-2016, 03:15 PM   #18
Good deal! Youroo!!
Old 04-05-2016, 06:15 PM   #19
Yep, that looks like a higher end faucet and I would have the dealer replace it if they're close by. You didn't say where you are and if freezing may have caused a crack. I've had that happen even after doing a good winterizing.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 06-23-2016, 12:32 AM   #20
As you say that the faucet is just a year old. Try repairing it first in order to understand what the real problem is. I had a similar issue way back at home and I had to called brothers plumbing Plumber Toronto, Plumbing Contractors | Brothers Plumbing Company to fix the faucet. Here are some diy steps that you could follow : Firstly make sure that the water supply is turned off.There will be screws that mounts the handle to the stem unscrew those and then remove the handle with a flat-head screwdriver. Any oil can help in loosening the faucet handle off the stem. Use the wrench to loosen the packing nut.You will be able to see the stem remove that as well. Then inspect the O-ring and the washer inside the valve seat, they could be a reason for the leak. Remove the washer and then put a replcement inside the seat. When you are doing the repair though make sure that the replacement washer and the O-Rings are an exact fit. If you are unsure about that you can just check the seat to see whether the sides fit a cone shaped or a flat washer. Then carefully reassemble all the parts .It should be in the order of washer/O-ring,stem,packing nut,screw and the handle.Slowly turn the knob to test the running water and check whether is it leaking again.If the problem still persists then you may have to buy a new faucet.
AndreaI is offline   Reply With Quote
faucet, leak
