Old 08-30-2013, 08:43 PM   #11
If you just use your pump you'll just have to get rid of the water inside the line in a bucket and after that have somebody switch on the pump for a few seconds that way you'll see if the clog is inside the line or at the faucet
jako is offline   Reply With Quote
Old 09-15-2013, 04:46 PM   #12
Quick update. I purchased a new house type faucet and installed it in the trailer. It works perfectly . Hot and cold water pressure is better than before.
The water lines were hard to unscrew but with lots of patience I managed to get the vice grips on there. Once the lines were loosened I used my hand.
Thank you everyone
2014 Salem 31' KQBTS TT
SOLD - 2011 Salem 30' QBSS TT
2006 Ford F-350, 6.0 PSD, 4x4, SRW, crew cab, short box
Equalizer hitch 14,000 lbs - weight distribution with sway control, 16" Raceline 870 aluminum wheels, Michelin LTX M/S tires LT225/75R16E
SnoSheriff is offline   Reply With Quote
faucet, hot water, pressure, water
