Old 01-10-2013, 06:23 PM   #1
Kitchen faucet problems
I have a 2006 Forest River Wildcat that I bought used. I have water to the shower, toilet and bathroom sink but no water to the kitchen faucet. I believe I do have water going to the faucet but no water when I turn it on. Could the faucet actually gone bad to not have water at all coming in? Will any brand of faucet work as a replacement as long as the hookups match and the measurements are the same as the faucet holes in the counter?
okhalftime01 is offline   Reply With Quote
Old 01-10-2013, 06:30 PM   #2
Great Horned Owl's Avatar
Any faucet will work, but you can also try unscrewing the aerator and either replacing it or cleaning out the screen.
Joel
2011 Silverado 2500HD Duramax, 4x4, crew cab, long bed
Palomino Puma 253-FBS, 27' 5th wheel
1994 19' Class B on Chevy chassis
Great Horned Owl is offline   Reply With Quote
Old 01-10-2013, 06:33 PM   #3
Herk7769's Avatar
I would:
1) Remove the faucet aerator screen - it could be clogged or rusted shut
2) Remove the valve(s) and inspect the rubber seals and springs - they may be clogged, hard and stuck, broken completely.
3) Since it was bought used, you could also have non-standard shut off valves in the lines or some other bizarre problem.
HAM CALLSIGN - KC3FFW
Old 01-10-2013, 06:34 PM   #4
faucet problems
I tried removing the aerator but still no water to the kitchen sink. . Also this is a one handle faucet that doesn't want to come apart to check. So minus the headache I will probably just buy a new faucet, one with both hot and cold handles.
Old 02-01-2013, 04:18 PM   #5
daydreaming about camping
jeeplj8's Avatar
Try Herk's advice above. The faucet is mostly the cassette style valve. Look for a way to remove the handle (set screw).
Also trace the lines going to the faucet itself.
While it is possible the faucet itself failed, usually failure is not be able to shut off rather than not turning on.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
faucet
