I have a 2006 Forest River Wildcat that I bought used. I have water to the shower, toilet and bathroom sink but no water to the kitchen faucet. I believe I do have water going to the faucet but no water when I turn it on. Could the faucet actually gone bad to not have water at all coming in? Will any brand of faucet work as a replacement as long as the hookups match and the measurements are the same as the faucet holes in the counter?
1) Remove the faucet aerator screen - it could be clogged or rusted shut
2) Remove the valve(s) and inspect the rubber seals and springs - they may be clogged, hard and stuck, broken completely.
3) Since it was bought used, you could also have non-standard shut off valves in the lines or some other bizarre problem.
I tried removing the aerator but still no water to the kitchen sink. . Also this is a one handle faucet that doesn't want to come apart to check. So minus the headache I will probably just buy a new faucet, one with both hot and cold handles.
