01-24-2017, 11:17 PM
#21
You have "104 Gal. of Gray water Capacity" that means you have More than 1 Gray tank! If you still have a Sierra 371 REBH! Youroo!!
01-24-2017, 11:18 PM
#22
Full-timing linewife
Well crap! We were never told that we had 2 tanks! Hubby is going back out again to look closer
#23
See the link posted
You should find the pull nearby to the outlet - you will have to make another connection to dump just the galley tank
Sent from my iPhone using Forest River Forums 🇺🇸
01-24-2017, 11:19 PM
#24
You did read post #7 on that link, right?
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
#25
Uhh I thought I did, let me double check
01-24-2017, 11:20 PM
#26
We found it!!!!!! Problem solved!
01-24-2017, 11:23 PM
#27
Okay - have to ask ..... you have been full time since July and have just now had a full galley tank ??? Do you not use the kitchen sink LOL 😊
Seriously - glad everyone could help
CAMP ON 👍🏻
01-24-2017, 11:25 PM
#28
Was it where the link said it would be?
Bob & Michelle
01-24-2017, 11:33 PM
#29
CAMP ON 👍🏻
Only thing we can figure is it was open prior to us moving in. Trust me, I use it a ton LOL family of 5 and we use a lot of dishes!
01-24-2017, 11:35 PM
#30
Yes it was! Thank you! 3.5 years full timing and we still learn new things haha
01-25-2017, 12:35 AM
#31
Thank you everyone for the help =) We are moving from Utah to Indiana/Ohio on Thursday so it was greatly appreciated!
01-25-2017, 11:45 AM
#32
Originally Posted by Shelbyprest
Update: we have done Drano AND a 25ft snake. We did it down the pipe and the roof vent. STILL will not drain.
I'm at a loss. What I going on?? As far as we know, we don't have a 2nd gray tank for the galley. We full time in ours and had it maintenanced a week ago. No issues until yesterday
don't ever ever use draino it's real bad on the plastic parts and tank . a snake is fine but should only need a few feet . you need to look for and make sure you do not have another grey tank . if the shower and lav drain fine but the kitchen does not you must have another grey tank . or your blockage is at the tank outlet
01-25-2017, 11:52 AM
#33
Our dealership recommended drano. We fixed it last night, thank you!
01-25-2017, 11:56 AM
#34
Draino's website claims it is "safe on all pipes." Almost all new houses these days have plastic drain lines and I've never heard a caution like this related to housing plumbing, so I'm not so sure that this isn't an old wive's tale.
2011 Traverse LT, 3.6L, FWD
01-25-2017, 12:17 PM
#35
DON'T use it in a sink connected to a Garbage Disposal though! It WILL eat the seals out of it......That's something that can only be fixed by replacing!
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
Nights Camped - (2014) - 16 in 6 trips (2015) - 20 in 6 trips
(2016) - 21 in 7 trips
(2017) - 12 in 3 and going seasonal for at least the rest of the year!
01-25-2017, 12:45 PM
#36
Interesting comment in as much as modern waste plumbing in your home is the same stuff in an RV.... and the tank material (plastic) is HDPE which is impervious to draino. No difference. Caustic Lye might be an issue, Draino isn't (an issue).
01-25-2017, 02:08 PM
#37
Check level of unit
Had same issue as u called factory said put
2" blocks on front
Corrected problem
Good luck
01-25-2017, 02:17 PM
#38
It's not the pipes it's the seals and sensors in the tanks . remember this is not a normal house
01-25-2017, 02:19 PM
#39
so you can't think of anything else that's in the tanks? just what there made of .
01-25-2017, 02:21 PM
#40
so i can't help it if your dealer doesn't know. so what was the problem you stated you fixed it . how ?
