Old 07-23-2016, 05:15 PM   #11
Head Rambler
It should be under warranty, so I think I'd let the dealer know what you've found and have them fix it.
Now, if you want to try and fix it, you may be able to remove the sink and run a root cutter head on a snake down the pipe and clear it out.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 07-24-2016, 11:51 AM   #12
This is what I a going to do. Went down and got an appointment. Every one down at the dealer seems to think the builder over glued every thing and there is a bunch of glue at the bottom of the pipe.
EddMc is offline   Reply With Quote
Old 09-05-2016, 12:20 PM   #13
Sorry for the delay in resolving this post, I am in the process of selling my house and buying another.
So the problem turned out to be that the drain pipe was all of the way to the bottom of the tank with barely any clearance to let the water into the tank. Toilet was actually plumbed the same way. Both fixed under warranty.
drain, sink
