Old 07-21-2016, 08:09 PM   #1
kitchen sink slow drain
Strange issue with kitchen sink.
This is on a Wolf Pup 16FQ we just bought in Aug of 15' been out camping only a few times and this issue has been steady from the beginning but i forgot about it until our last outing.
OK on with the symptoms, when using the sink if you run the water slowly (only one side open) every thing works fine but if you run it on full (both hot and cold) or dump some water in the sink it will drain very very slowly. It has a under the counter vent which is tight against the bottom of the counter. I actually had to remove the cap to get the vent out of the pipe. With the vent removed the problem still persists, and water will actually flow out of the top of the pipe if the level in the sink is above it.
EddMc is offline   Reply With Quote
Old 07-22-2016, 08:21 AM   #2
Head Rambler
Have you removed the trap under the sink to see if there's something caught in it?
If not, while you have it out either take a picture down the drain pipe or use an inspection mirror to look down it and see if you see anything.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 07-22-2016, 08:28 AM   #3
The trap is clear. I will try to take a picture down the drain, that is a good idea.
Old 07-22-2016, 08:31 AM   #4
SeaDog's Avatar
It might be that the hole was never actually cut out all the way in the tank and is obstructing flow. Now that is just a wild guess on my part in any case let us know what you find.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
SeaDog is online now   Reply With Quote
Old 07-22-2016, 12:20 PM   #5
these are the best I could get.
Old 07-22-2016, 12:23 PM   #6
Here are some of under the sink.
Vent out.
Vent in (missing the cap)
Attempt at getting all of it.
Old 07-22-2016, 02:23 PM   #7
Issue with drain on rv
Do not know if it will help but had same issue with our Sunseeker
Talked with factory and they suggested a 2 or 3 " rise on the front
We did this with wood blocks and it corrected the problem
Seems as if they did not get the proper incline when they set the piping
Hopes this helps
stervin is offline   Reply With Quote
Old 07-22-2016, 02:44 PM   #8
Head Rambler
Looks like there's some glue or something near the bottom of the piping. That may be the problem.
Gotta go campin!
Old 07-22-2016, 03:35 PM   #9
Hopes this helps
Thought about that and raised the front and no good.
Old 07-22-2016, 03:37 PM   #10
This is what I am thinking, they way over glued all of the joints.
drain, sink
