It's basically a sticky rubber tape that's real stretchy but is water proof. On wiring exposed to the elements, where a heat shrink won't work, I'll wrap it in aqua seal (not a brand name, just what we call it at work), then black tape.
Found the problem fellas! I traced the toilet supply line, was able to pull from underneath after I un hooked it from the toilet, had enough slack pull enough to fine the hole while still leaving about 6 inches hanging out of the interior wall so I didn't lose it.
Dang field mouse got hungry!
I did my best at keeping them out over the winter, but 1 or 2 still got in. Any ways, I cut the bad spot out obviously, and sleeved it. All is good it seems!
Thanks for all the advice.
Hope that mouse got a belly full of "pink coolade"!
What type of clamp was on the fitting & what did you replace them with?
2014 Prime Time Sanibel 3250
