Old 04-17-2016, 11:39 AM   #21
davidjb's Avatar
Thats ok I'm taping my power wire for the same reason, luckily just the outer black coating
davidjb is offline   Reply With Quote
Old 04-17-2016, 05:06 PM   #22
I like to throw a bit of aqua seal on too to help fight corrosion. Or a shrink of its a larger wire size.
BobSagetIsGod is offline   Reply With Quote
Old 04-17-2016, 06:00 PM   #23
davidjb's Avatar
What is aqua seal?
Old 04-17-2016, 06:49 PM   #24
It's basically a sticky rubber tape that's real stretchy but is water proof. On wiring exposed to the elements, where a heat shrink won't work, I'll wrap it in aqua seal (not a brand name, just what we call it at work), then black tape.
Old 04-17-2016, 07:47 PM   #25
rracer5's Avatar
Originally Posted by BobSagetIsGod View Post
Found the problem fellas! I traced the toilet supply line, was able to pull from underneath after I un hooked it from the toilet, had enough slack pull enough to fine the hole while still leaving about 6 inches hanging out of the interior wall so I didn't lose it.
Dang field mouse got hungry!
I did my best at keeping them out over the winter, but 1 or 2 still got in. Any ways, I cut the bad spot out obviously, and sleeved it. All is good it seems!
Thanks for all the advice.
Hope that mouse got a belly full of "pink coolade"!
What type of clamp was on the fitting & what did you replace them with?
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 04-17-2016, 07:47 PM   #26
davidjb's Avatar
O ok I know what you mean, Thanks
Old 04-17-2016, 08:45 PM   #27
Hey ate that right out of the middle of the hose, I cut the section out and just splice it back together with a brass male to male fitting.
lacrosse
