Old 10-12-2019, 12:28 PM   #1
leak
I have a 2015 puma 30 fbss. we have been using it a lot since purchase in 2017. recently we have noticed dripping from the tub kitchen side of the camper after the shower has been used, behind the tire fender, front and rear steps. there is no moisture or water visible from the access panels at the tub or water heater on the floor vinyl, pex piping, or abs waste piping. if I lay down beside the camper tires when the leaking is happening i can here dripping above the enclosed floor. this just started on its own about a week ago. is there anyone out there who knows what could be leaking? or have a plumbing schematic I can refer to for potential repair procedures? I bought this used but according to the research i did I have an artic package with an enclosed bottom.
Thank you
essler
essler is offline   Reply With Quote
Old 10-12-2019, 05:52 PM   #2
Iwannacamp's Avatar
Some/most have a panel that is screwed on on/in front of/behind the shower wall somewhere. Might be able to see the issue if you remove the panel.
Might use one of those fittings you blow out the water lines with and pressure up the water system to leak check/check for water leaks. Better that than the shower drain leaking.
2017 Puma 297RLSS
leak
